Real world COP vs. manufacturer claim
I think that I would prefer a heat pump from a well known Japanese company, particularly after looking in detail at the data obtained under standard testing procedures, which clearly showed that the Ecodan units could be expected to achieve their specified output rating down to something like -15C.
You are perfectly correct that to obtain the full benefits of a well designed and built heat pump, you also need your whole system to be well designed and installed.
Vaillant Arotherm yeild and COP readings
11 months ago
Viessmann Vitocal 250-A in the UK
1 year ago
Slash Your Heat Pump Bills Overnight
2 years ago
Does your heat pump calculate and provide you with a COP figure?
2 years ago
Daikin EDLA14D3V3 COP is now below 1
3 years ago
- 18 Online
By Scalextrix , 7 hours ago
By HCas , 9 hours ago
By GrahamF , 12 hours ago
By immunity , 14 hours ago
By JamesPa , 19 hours ago
Just done your survey!
By Judith , 1 day ago
By Tasos , 1 day ago
By Scalextrix , 2 days ago
By bontwoody , 3 days ago
By Alex , 3 days ago
By GrahamF , 3 days ago
By DREI , 4 days ago
By Profzarkov , 4 days ago
