Mine was so bad Mars wrote an article on it. But for the installation itself. No handover, flow temperature at 55 degrees, no weather compensation, hot water return pump running constantly - frankly they had no clue and were just plumbers (and not especially good at that). Make good was poor.
Since joining the forum and with the help of Vailant's excellent customer service we have a heat pump running well and efficiently.
@witchcraft Sorry to hear that. I'd read your article and it does sound like a really shocking experience.
I suspect most people on here are the sort who like to work things out and gain a greater understanding of what is going on. Not everybody is like that though and they need to be confident when they pay for heat pump installation they get a proper service.
As I've gained knowledge through going through this process, it seems to me that the biggest issue is the lack of consideration of efficiency in heating installation. For example, I wonder how much excess gas has been burned over the years through poor and inefficient installation of boilers. Because gas has been cheap and nobody really noticed, boiler installers basically whacked it up, home owners got heat and were happy. But the energy crisis has shown us that insulation, efficiency and electrification now has to be the solution.
Hi. I've just joined the forum and spotted this post.
I've voted average but actually feel it's closer to poor. I was very lucky to have a full system fitted on eco4 as my father in law is on ESA after a heart op. I've had a Samsung gen 6 12kw ASHP two zone fitted with new rads and pipework throughout. It's an all rad system, no UFH.
It seems my experience is fairly common with others who have had ASHP fitted on eco4. Basically the system is put in as quickly as possible and left on high defaults, no legionella (which I would turn off anyway) and told just to turn it on and off with the room stats. I'm not one to do as I'm told so I instantly started researching to find out about WC etc and how to make it more efficient. I've learnt more everyday. It's no wonder ASHP has a reputation as being expensive to run as it would be if I'd just left the system as it was handed over. I imagine most people do just that.
There needs to be a lot more education for fitters and from fitters to end users. ASHP manufacturers could make them a lot less confusing too.
Our experience mitsubishi ecodan 11.2k
New build, zero information told by installer to set and forget at 60 fixed flow ( roll eyes), after loads of research we have finally got the system working both efficiently and the house is warm.
We have no gas in the village we live in, so ashp on paper looked like the best option. When we moved in we had no idea how the system worked, from an end user perspective felt like we were chasing the elusive "sweet spot" which is ridicules and very frustrating, tech should just work in my opinion.
What worked for us was that we bought another wireless controller that we added to the system then after placing it around the house we finally found the correct placement. (Another eye roll, really should this not just work whereever it is placed)
The house is now comfortable on weather comp. so far this winter saved 220kwh on last year, target temp is 19 but always overshoots, which suits us fine.
I do despair for most end users, its not an easy set up to understand and can be expensive without loads of research and help from this forum.
Voted average, but verging on poor. We have been trying to contact the installers since Sept for a service, thankfully the system is working OK. On the Mitsubishi website the installers are still accredited, should this be the case? if they cant even respond to customers.
Voted average for a vaillant installation
No heat loss calc provided, no design provided. Installation done blindly due to poor communications from installer. installer basically connected the pump with no instructions on how to use - I suspect this is to increase the number of their call-outs at costs. Pump is oversized, not insulated which indicates loss efficiency and I’ve had to do a lot of research to try to understand what is going on. Still ongoing issues. Very mixed feelings.
Posted by: @gemiarNo heat loss calc provided, no design provided. Installation done blindly due to poor communications from installer. installer basically connected the pump with no instructions on how to use - I suspect this is to increase the number of their call-outs at costs. Pump is oversized, not insulated which indicates loss efficiency and I’ve had to do a lot of research to try to understand what is going on. Still ongoing issues. Very mixed feelings.
If that gets an average vote, I wonder, how bad do they have to be to to get a poor/absolutely shocking vote?
@cathoderay Based on the questions they got an average score, if you asked me my views they were charlatans who had no concept of how ASHPs run nor any idea of customer care or service.
@gemiar, welcome to the forums and thanks for sharing. Please feel free to start a new topic for your set up and let us know what your running costs are like, which you can do here: RE: What's your current daily damage?
@cathoderay well, I am being generous here. I do get hot water and heating but at excessive cost. It’s ongoing and I am trying to educate myself on what expectations with ASHP should be - I’m a consumer with no technical plumbing/installation knowledge. The installer also uses this to their advantage sadly. This forum has been really helpful.
Posted by: @gemiarVoted average for a vaillant installation
Was this company MCS accredited? If so, they should be reported for failing to meet the required standard.
Is this ASHP install OK?
3 weeks ago
My Journey to Finding the Best Heat Pump for My Home in France
6 months ago
What is the most important factor for you when choosing a heat pump brand?
1 year ago
Mid terrace - ASHP Install location
1 year ago
Any installer recommendations for Samsung ASHP?
1 year ago
- 2,131 Topics
- 19 Online
- 5,656 Members
By Old_Scientist , 11 hours ago
By Transparent , 15 hours ago
By PatrickVito , 2 days ago
By Tim441 , 3 days ago
By Tim441 , 5 days ago
By Toodles , 5 days ago
By Abernyte , 5 days ago
By Eliuccio , 6 days ago
By Scalextrix , 6 days ago
By Mars , 7 days ago
By Mars , 1 week ago
By Scalextrix , 1 week ago
By JamesPa , 2 weeks ago
