I'm so confused and...
I'm so confused and worried about the running costs of my heat pump. Please help!
7 Users
11 Reactions
(@benseb)
Hopefully someone with the same ASHP can talk you through that 🙂 I have a different one I’m afraid.
@winnie-wicket
What is the size of your home and how many rooms are there?
Do you have a Smart meter.
Without giving away 'state secrets', could you provide details of your bills from before the heat pump was installed and since it was installed.
@winnie-wicket, Daikin have contacted me and have asked if I can share your contact details with them so that they can send someone out to have a look. Please let me know. Feel free to DM me.
(@winnie-wicket)
Posted by: @editor
Oh wow, that is fantastic, would it be expensive though? I,ll pm you.
(@winnie-wicket)
Hi I think I've pmd you..I can't see if it sent? Thankyou.
(@winnie-wicket)
@winnie-wicket
It's a small 2 bed bungalow. One lounge, kitchen and bathroom.
My bills have varied because the situation here has been confusing really. I,ll try to remember what I can but I have memory problems.
When I first moved in here 15 years ago I had economy 7.    After about 5 years they changed my heating to normal type  I. also had a solar hot water panel that was on the side of my bungalow and it was brilliant, never any trouble.  The New central heating was French and when it broke down they couldn't get the parts that needed replacing  so after being without proper heating while they tried to get the part, they then told me I was having this new ashp fitted. When they did it they removed the hot water solar panel.
My bills with the normal heating system were around 60.00 a month.
My bills with the ashp rose to around 160.00. My energy provider Bulb now want upwards of 400.00 a month direct debit to cover my estimated usage this winter.
(@hughf)
Posted by: @winnie-wicket
@winnie-wicket
Do you have the date at which the ASHP was installed and commissioned? Electricity has risen from 15p/unit (for arguments sake) to 34p/unit over the last 18 months, in two different steps (29p/unit was from April '22 to October '22) so that needs to be considered when looking at your bills.
@winnie-wicket
First of all I cannot understand why they would remove what sounds to have been a solar thermal system, since it could have been incorporated with an ASHP and the correct hot water cylinder.
Ideally we need to know your consumption in kWh's, since tariffs have varied over recent time periods. Do you have a Smart meter?
I think that you should also ask Bulb to provide a breakdown of how they arrive at a figure of £400 per month. This would seem rather excessive for a small 2 bedroom property.
(@hughf)
@winnie-wicket
Total failure to properly design the system, lack of installer knowledge, etc etc etc.... Standard...
(@winnie-wicket)
Here are some readings, according to the smart meter.  Some from last year, some from after April when costs went up and some up to now.  I don't have any of the oil filled radiators on, no heating at all, just the tv and 2 lamps right now.
(@winnie-wicket)
Sorry. Will try again
IMG 20221023 185346989 HDR
IMG 20221023 185427551 HDR
IMG 20221023 185356806 HDR
(@winnie-wicket)
IMG 20221023 185502972 HDR
IMG 20221023 185512641 HDR
IMG 20221023 185519242 HDR
Page 3 / 5
