Low Flow Rate Error - 8 kW Ideal Logic ASHP - Help!
@cathoderay Ahh yes, the large white tank is an Ideal Logic Pre-Plumbed cylinder, so theres a 180l hot water tank at the top and the heating pipes run through the bottom which is why the CH1 pump is there - Long Welsh cottage needs some help with circulation! I believe there is an integrated buffer in the tank.
@wh0am3ye - OK, starting to make sense, but it does mean you have a buffer which as you will know from this forum is usually, though not always, not ideal, despite the brand name. But you are where you are, as indeed am I. I have a plate heat exchanger between the primary and secondary circuits, some loss of efficiency, but I have kept it for now as it does keep the potentially dirtier (though in practice so far it hasn't been) radiator circuit separate from the primary circuit.
- 366 Online
By Bash , 4 minutes ago
By Toodles , 13 minutes ago
By Majordennisbloodnok , 32 minutes ago
By benson , 37 minutes ago
By trebor12345 , 1 hour ago
By Travellingwave , 2 hours ago
By RobS , 2 hours ago
By Batpred , 4 hours ago
By GC61 , 6 hours ago
By cathodeRay , 10 hours ago
By JamesPa , 20 hours ago
By Batpred , 22 hours ago
By DavidB , 1 day ago
By Slartibartfast , 1 day ago
