Can anyone hazard a guess as to why water is coming out of this wee pipe outside my house? I remember the engineers referred to it as the “run off” or something like that. The cylinder is whooshing too, like water coming in or out of it.
it did it last week for about 20 minutes too.
I just can’t seem to find anything in my documents or online as to what this is.
Posted by: @marvinator80Can anyone hazard a guess as to why water is coming out of this wee pipe outside my house? I remember the engineers referred to it as the “run off” or something like that. The cylinder is whooshing too, like water coming in or out of it.
Is the water coming out of the pipe hot? Where does the pipe connect inside your home? Is the water in the tank getting too hot?
@derek-m seems to be warm water. Weird.
The hot water is on a top up cycle and stuck at 37 degrees while it does this.
if I turn on a hot water tap the whooshing stops but it’s not hot coming out of the tap.
Water temp now up to 39 but still cold out of tap while this whooshing noise and outside flow continues.
Posted by: @marvinator80@derek-m seems to be warm water. Weird.
Can you provide photo's of where this overflow pipe is connected inside your home?
Is there a pressure relief valve installed within this pipework?
@derek-m it goes straight through the wall seemingly from the cylinder but it’s hard to see the full workings now with the cupboard.
You may have to employ a hand mirror.
Can you make a sketch of where the pipework connects and identify any equipment fitted to the pipework.
- 2,118 Topics
- 46.5 K Posts
- 49 Online
- 4,522 Members
By Mars , 1 hour ago
@adamk what a shambles. Can you share some pics of the ...
By JamesPa , 5 hours ago
So the manual is correct and looks fine to me, to abbre...
By ASHP-BOBBA , 11 hours ago
By Transparent , 12 hours ago
By normpang , 13 hours ago
By ASHP-BOBBA , 1 day ago
By Toodles , 1 day ago
By Old_Scientist , 1 day ago
By Burtis , 5 days ago
By JamesPa , 5 days ago
By Old_Scientist , 6 days ago
By Lucia , 6 days ago
By Ashfp , 6 days ago
By Mars , 1 week ago
