HP Cycling, Expected or Undesirable
@old_scientist Hi, yes I was comparing COP without taking the cycling into account.
Just a little update. I ordered a longer shielded twin core wire and moved the control pad/thermostat into the living room from the hall where it was set to 24C allowing me to run on pure weather compensation. Ive lowered it now to 22C to limit the living room temp.
Last nights graph was very promising.
I finished the switch at 19.40 when the pump was cycling and the thermostat did its job keeping the room toasty and elongating the off periods. Ill have a play with WC settings over the next week or so and see if I can lower the flow temperature further.
- 2,114 Topics
- 46.4 K Posts
- 50 Online
- 3,410 Members
By Grantmethestrength , 18 hours ago
By Brendon Uys , 2 days ago
By Burtis , 3 days ago
By trebor12345 , 3 days ago
By Lucia , 4 days ago
By Ashfp , 4 days ago
By Transparent , 5 days ago
By Mars , 6 days ago
By Mars , 1 week ago
By Prunus , 1 week ago
