[Solved] How to program setback (Ecodan 5.0)
@abernyte that is excellent. Very helpful. Thank you so much.
@abernyte Sorry, one more question. When setting for Room, Flow or Curve is it safe to assume that Room is Auto Adapt?
Just found this.
@afarmery did you ever resolve the issues you were battling with? Any updates would be appreciated.
Also, what is the size (kW) of your Ecodan?
- @editor I didn't resolve the issue really. My system is an Ecodan 5kW. I understand that it might be possible using Melcloud (but I'd need to buy an Ecodan WiFi adapter). In the end, I just implement setback manually. I've got the curve calibrated nicely to give room temps of about 19.5. The stats are set to 21, as a temp limiter. When I go to bed I nudge the curve down by 1 or 2 degrees on the FTC6 panel, then nudge it back in the morning. Power consumption is pretty meagre and I can mostly satisfy it with my solar panels and battery.
- 2,114 Topics
- 46.4 K Posts
- 98 Online
- 3,410 Members
Delighted to hear this went well. It looks very neat ...
By JamesPa , 7 hours ago
The issue with the Grant is that you have to wire direc...
By Grantmethestrength , 11 hours ago
By Toodles , 11 hours ago
By Brendon Uys , 15 hours ago
By Burtis , 1 day ago
By trebor12345 , 2 days ago
By Lucia , 2 days ago
By Ashfp , 3 days ago
By Mars , 6 days ago
By Prunus , 6 days ago
By Mars , 7 days ago
