How to program setb...
[Solved] How to program setback (Ecodan 5.0)
5 Users
5 Reactions
Abernyte
(@abernyte)
Melcoud1
Does this give you the idea?
Melcoud2
Morgan
(@morgan)
@abernyte that is excellent.  Very helpful.  Thank you so much.
Morgan
(@morgan)
@abernyte   Sorry, one more question. When setting for Room, Flow or Curve is it safe to assume that Room is Auto Adapt?
Morgan
(@morgan)
Just found this.
Abernyte
(@abernyte)
Yeah, room is AA
@afarmery did you ever resolve the issues you were battling with? Any updates would be appreciated.
Also, what is the size (kW) of your Ecodan?
(@afarmery)
  • @editor I didn't resolve the issue really. My system is an Ecodan 5kW.   I understand that it might be possible using Melcloud (but I'd need to buy an Ecodan WiFi adapter).   In the end, I just implement setback manually.   I've got the curve calibrated nicely to give room temps of about 19.5.  The stats are set to 21, as a temp limiter.   When I go to bed I nudge the curve down by 1 or 2 degrees on the FTC6 panel, then nudge it back in the morning.  Power consumption is pretty meagre and I can mostly satisfy it with my solar panels and battery.
Page 2 / 2
