Heat pump not reaching flow temperature
Posted by: @davecit wasn’t until later when we realised that the WC wasn’t being applied to the set FT that was causing the issue and we started to manually alter the FT to allow the ASHP to back off the compressor frequency and improve the efficiency.
I would describe this as either a fault or a configuration error. If the ft isn't changing with oat then wc isn't working, your heat pump won't be efficient, and you won't be comfortable. The installer needs to fix this, as it stands it isn't fit for purpose. He also needs to explain how to adjust the WC. Don't accept any excuses this is just wrong!
- 2,406 Topics
- 54.6 K Posts
- 310 Online
- 6,092 Members
RE: Vaillant aroTherm not heating with many faults
@editor hmmm, our engineers Rae, Craig, Naz, Rob and Ry...
By ASHP-BOBBA , 25 minutes ago
RE: Post-Traumatic Heat Pump Stress Disorder
@editor Hi Mars. I totally agree with your comments. ...
By Richard24738 , 28 minutes ago
Indeed! And my apologies, I should have expected you...
By Batpred , 45 minutes ago
RE: I’m glad the cold spell is over!
@editor as a reply for this date the 6th of Jan in o...
By Nursethescreens , 2 hours ago
RE: Experience - New Build / Complete New Heating System
@bash you and me both, can agree. Nothing like shooti...
By vincro , 2 hours ago
RE: Heat loss based on gas usage
@jamespa Thanks. The numbers posted above were jus...
By Bash , 2 hours ago
RE: Heat pump not reaching flow temperature
I would describe this as either a fault or a configurat...
By JamesPa , 3 hours ago
@batpred I started reading this thread thinking I would...
By Hook , 4 hours ago
RE: Please help with the settings ecodan
@sheriff-fatman when I increase it to number 3, the ...
By nose1972 , 5 hours ago
RE: New Daikin 11kW Altherma 3M install - is it working as it should?
I forgot to mention: Octopus measured our heat loss at ...
By Toodles , 6 hours ago
RE: Considering MLCP (Multi-Layer Composite Pipe) for ASHP
Thanks Mars and thank you for reaching out to so many p...
By iotum , 6 hours ago
Forum Handle: @davec Manufacturer: Peak Energy Mode...
By DaveC , 6 hours ago
Well, the guy came out, turned the heat pump to max, we...
By razz , 6 hours ago
Midea R32 setup and bizarre running with lengthy off periods?
Hi I am new to the world of ASHP and have just had a re...
By Countryman Helmsley , 7 hours ago
Given the weather has been relatively stable, the empir...
By Batpred , 7 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@editor That is very kind! Thank you so much.
By johnbroome , 8 hours ago
@wally Hi I am not sure how large your house is b...
By TechnoGeek , 9 hours ago
RE: Predicted Heat Loss & Needs from MCS calcs vs EPC vs actual
I've been thinking along similar lines to @tim441 from ...
By Sheriff Fatman , 10 hours ago
Thanks, @technogeek. Good to hear about the accuracy. ...
In my case it was a very specific pattern of behaviour ...
