External stat issue
5 Users
3 Reactions
@cliffhanger - seriously though, I have no idea. What I do know is that any sensor can be duff eg the one that tells you your car is over-heating when it isn't. If you've checked it against two mercury thermometers, then collect some evidence and go back to whoever is covering the guarantee.
Posted by: @cliffhanger
Looks like I will have to make curve changes as it is consistently inaccurate.   Still under guarantee incidentally.  Are they as accurate normally as Mercury?
WC curve best discovered by experiment anyway as any loss calculation (on which a theoretical determination of the WC curve would be based) is at best an estimate and at worst almost total fiction.
If its consistent I wouldn't worry too much about unless its somehow causing confusion.  There may even be an 'OAT offset' adjustment in the installer menu.
(@cliffhanger)
@jamespa
Thanks. Yeah any adjustments Ive made at present seem to make little difference.
May pursue the guarantee dunno yet
Cliff
(@judith)
Accuracy of -/+1C is normal
(@cliffhanger)
@judith
Applied for replacement from installer.   If not they're 20.00.  May just get one.  Easy installation.
Page 2 / 2
