Electricity use for heat pumps - comparing homes and consumption
Posted by: @mike-patrickMany of the above , in my dreams.
2023, June 479, Nov 1,120, Dec 1,359, Jan 2024 1,491
These are total kWh per month from which you can subtract 8-10kWh per day for non-ASHP use - say 300kWh per month.
100% electric home. 10KW Grant Aerona, 3 bed detached (150 sqm), mixture of cavity wall insulated new build and internally insulated original stone, double glazed, UFH no radiators. 20c heating. ASHP left on same settings 24/7. UFH off during summer months, 2 occupiers.
How old's your home?
2023 Nov 608, Dec 690; 2024 Jan 886, Feb 564
100% electric 1990ish home, 8.5kW Mitsubishi Ecodan, 4 bed semi (128 m² IIRC), injected cavity wall insulation, double glazed, all radiators, 20c heating (give or take a degree), ASHP set back to 18c overnight, heating does its own thing so rarely on in summer, 2 occupiers.
242sqm new build, house 21/22. Nov Dec 2023 approx 1400kwh. Near 40% less then my first winter thanks to suggestions here, I'm setting back overnight as house retains heat well. All ufh using fixed flow temp.
I have now posted the % comparison between measured energy consumption and the estimates provided by my Ecodan. Upthread I'd said that I would do this but you would be forgiven if you'd lost patience during the long time since!
- 2,152 Topics
- 47.2 K Posts
- 41 Online
- 5,671 Members
@pash44pump - @jamespa has already come up with some us...
By cathodeRay , 55 minutes ago
@bontwoody Maybe one for @editor to consider whether a ...
By ChandyKris , 2 hours ago
@scalextrix yes, battery is vital to maximise TOU tarif...
By Tim441 , 2 hours ago
@howardp99 Yes, I get how the inverter rating is limiti...
@mars That response surely deserves a nomination for Tu...
By JamesPa , 16 hours ago
Specifying batteries, pv solar etc using ChatGPT
I thought I'd try to use ChatGPT to specify my requirem...
By Tim441 , 18 hours ago
When I interviewed Mitsubishi Electric at Installer ear...
By Mars , 22 hours ago
@lucia One look at that protection and the rodents will...
By Toodles , 23 hours ago
By Lucia , 1 day ago
What is the Heat Geek Guarantee?
We regularly hear from homeowners who are researching i...
@adamk, interesting point. I’ve not focused much on Hea...
Intelligent Octopus Flux (IOF) Review
I promised @toodles that I would provide an update and ...
@julianc Our solar PV has produced more this August tha...
By Jeff , 3 days ago
By GrahamF , 4 days ago
By cathodeRay , 4 days ago
By benson , 4 days ago
