Ecodan with FTC7 co...
Ecodan with FTC7 controller DHW schedule
6 Users
0 Reactions
 Gary
(@gary)
@davidalgarve There are 2 heating modes for DHW Eco and Std, Eco as it suggests uses less input power but takes longer, so if you aren't on that already you could change it.
There is also the speed of the pump to the cylinder you could alter that and see what impact it has on input power, either way its going to take longer to heat the water if you are using less power.
(@davidalgarve)
Hi Gary,
I am away from home at the moment so cannot check, but is that feature only on the FTC7? I don’t recall the Eco feature on my FTC6. Pump speed 3 or 5 doesn’t make much difference.
This post was modified 6 months ago by DavidAlgarve
 Gary
(@gary)
The hot water mode is the settings on FTC6, I think you are thinking of separate pump speeds for heating and DHW which is only on FTC 7, its in the video below.
To change HW pump speed on an Ecodan with FTC6 then you need to move the manual switch on the side of the pump with 3 different positions
This post was modified 6 months ago 2 times by Gary
(@davidalgarve)
Thanks Gary. I had forgotten the Normal/ Eco setting and remembered it as soon as I saw the picture, and I will now try it and see what difference it makes.
On my Hydrobox, there is no facility to change pump speed manually, but I can change independently the pump speed for both house and DHW on the control panel.
Currently I have both on 3 and wonder if reducing this for DHW, would result in more cycling.
Page 2 / 2
AI Chatbot Avatar
AI Engine
Talk to
Wattson:
AI Avatar
Welcome to Renewable Heating Hub! Ask me anything about heat pumps: how they work, running costs or even how to find installers in your area.
By using this chatbot, you agree to the recording and processing of your data by our website and the external services it might use (LLMs, vector databases, etc.).
