Ecodan software update. Real or scam?
Just received an email telling me that my Ecodan ASHP requires a software update. Anybody else had this and confirm it isn't a scam of some sort please?
email is from: meu-uk.lesecodanquality@meuk
It may be okay and probably is legit but we have not yet been told the reason for the yet to be fully fixed MelCloud borkage. I, being a cynical and over cautious type would hold off for now or give Mitsibushi Support a call first.
@abernyte Sound advice, cheers. Did you get the same email?
Posted by: @morganJust received an email telling me that my Ecodan ASHP requires a software update. Anybody else had this and confirm it isn't a scam of some sort please?
Was there a copy and paste issue with the original post? Was the email address meu-uk.lesecodanquality@meuk.mee.com
No but I am still not back connected. I am in the 40% who didn't reconnect automatically and are still being rejected by the authentication server
@editor it appears so. The address should be. meu-uk.lesecodanquality@meuk.mee.com
@Morgan then that looks legit to me, because the people I know and communicate with at Mitsubishi all use the same email address extension/domain: @meuk.mee.com
@editor thanks for that Mars. I’ve never had email contact with Mitsubishi before. The more I looked at it it did seem legit but one cannot be too careful these days, especially given there is mention in the email of confirming various details and that a Mitsi agent will require access to the outside and inside components.
Edit. I forgot to mention that a software update was applied at service Feb 2024.
Thanks again.
Posted by: @abernyteNo but I am still not back connected. I am in the 40% who didn't reconnect automatically and are still being rejected by the authentication server
Have you established, or have Mitsubishi confirmed, what the cause of the issue is?
Posted by: @morgan@editor thanks for that Mars. I’ve never had email contact with Mitsubishi before. The more I looked at it it did seem legit but one cannot be too careful these days, especially given there is mention in the email of confirming various details and that a Mitsi agent will require access to the outside and inside components.
Thanks again.
1000% – I regularly check and triple emails that look suspicious – you can never be too careful these days.
@abernyte, hmm, must have been a major disruption if 40% of users still can’t reconnect.
- 22 Forums
- 2,084 Topics
- 46 K Posts
- 49 Online
- 3,377 Members
@tomasmcguinness bold choice on the Kronoterm. Nice! Wi...
By Mars , 1 hour ago
It took me more than a few goes as well, plus some help...
By cathodeRay , 18 hours ago
@jamespa I have a hydronic baseboard heater in the kitc...
By Scalextrix , 2 days ago
By Bart , 2 days ago
Here’s a little more technical detail/p>
By Judith , 3 days ago
By AF1 , 4 days ago
By Old_Scientist , 5 days ago
RE: Plate heat exchanger considerations
As far as I can tell my vented system would have a peak...
By Scalextrix , 6 days ago
RE: Air Changes per Hour - ACH and the MCS requirement
There have been a few discussions dotted around (e.g. I...
By Declan90 , 6 days ago
