Ecodan circulation pump
Hi All, I’m looking for some advice please. I had an ashp from Earth Save Products which recently failed and I have just replaced it with a Mitsubishi Ecodan 11.5kW. The ashp provides heating to my ufh only. My hot water is generated by a separate system. The ashp feeds a buffer tank for my ufh and I have stats in each room which call when heat is required. The stats activate the flow pumps for each zone and these are connected to the Mitsubishi control panel via a volt free contact. This all works perfectly and I’m achieving good results. My confusion is that the circulation pump which is installed in my utility room next to the buffer tank runs 24/7. It runs when heating is not being called by the system and when the ashp outside is not running. I have monitored and it runs all the time, not just an overrun when the ashp has just switched off. Outside air temps have been between -4 and +7 deg C and no difference. Clearly this is not normal as it should only run and circulate water when heating is called and the ashp is running + a short overrun. Does anyone know where I should have this pump connected to in the control panel? Maybe we have it wrong or are missing a signal? Any help would be great. Thanks. Adam.
Posted by: @adambaHi All, I’m looking for some advice please. I had an ashp from Earth Save Products which recently failed and I have just replaced it with a Mitsubishi Ecodan 11.5kW. The ashp provides heating to my ufh only. My hot water is generated by a separate system. The ashp feeds a buffer tank for my ufh and I have stats in each room which call when heat is required. The stats activate the flow pumps for each zone and these are connected to the Mitsubishi control panel via a volt free contact. This all works perfectly and I’m achieving good results. My confusion is that the circulation pump which is installed in my utility room next to the buffer tank runs 24/7. It runs when heating is not being called by the system and when the ashp outside is not running. I have monitored and it runs all the time, not just an overrun when the ashp has just switched off. Outside air temps have been between -4 and +7 deg C and no difference. Clearly this is not normal as it should only run and circulate water when heating is called and the ashp is running + a short overrun. Does anyone know where I should have this pump connected to in the control panel? Maybe we have it wrong or are missing a signal? Any help would be great. Thanks. Adam.
Where is your water pump connected at the moment? Photo's may be useful.
@sunandair hi, thanks for your input. I’m new to the Mitsubishi system, so please can you tell me where and how to adjust the Frost protection?
I assume this is Frost protection of the ashp outside? I have glycol at about 20%. My thought is I wouldn’t need a high temp for the Frost protection?
thanks. Adam.
@adamba If you are familiar with the buttons on your FTC main controller you can check what your ecodan freeze function is set at? This is a quick check which may be all that is wrong.
If you have access to your controller here is a sequence of screens to access the
Freeze Stat Function
- press the left Menu Button
- select the Service Button
- enter password = 0000
- Select Operation Settings (accept yes to shut the heat pump down temporarily) then re-select Operation Settings
- Select Freeze Stat Function
in that screen you will see 2 windows
FlowT and Ambient
your set outdoor temperature which will trigger the pumps to come on is shown in the “Ambient”window.
Can you write down and confirm what temperature does the Ambient window show?
you can exit the Operation settings by pressing the back- arrow button twice then leave the service screen. Press the YES button. Then press the back-arrow button again to get back to a blank screen.
Then to restart the heat pump press the round on/off 🧳 key
@sunandair excellent thanks - I’ll try this tonight and will confirm.
As a separate thought - does the internal circulation pump have to be set on the keypad to only run when the ashp runs? I guess this would be the only other reason the pump doesn’t stop/start with the ashp? I’m not sure if it can be set to permanently on?
@adamba hi
Since you’ve got glycol you could set your frost-protect down to zero if it’s not already set to that temperature *But please let us know what temperature it’s set at currently before you change anything if you don’t mind 👍
The HP needs to switch the circulation pump/s on at various times - such as defrosting when the grills ice up, or to pre-circulate the water before it starts the heat pump. They really are very clever at looking after themselves. The problem you are hinting at would be if the installer has done something unusual for some reason.
@derek-m is already checking via your pictures what else might be going on with your assembly. He has far More extensive knowledge of variations in systems than could hope to know.
please report back what you find when you get back home, let’s hope it just needs an easy adjustment.....
@sunandair - thanks both for all your help so far. Here is a pile of photos just taken. Will wait to hear your thoughts. Thanks in advance. Adam.
Hi @adamba
thanks for the information you’ve sent.
Regarding the Freeze Stat Function.You can adjust this down to a lower temperature without affecting other settings. However looking at your setup I can see you’ve got underfloor heating in four zones so I think this system is more efficient to operate continuously but at a low flow temperature.
The way under floor heating works is to gently warm large mass floor areas which if set up properly is the most efficient way to use your Ecodan heat pump.
So while you can lower your freeze stat function the heating method may still be better operating continuously at low heat output.
hope this helps
@sunandair My freeze Stat settings are as yours (20c Flow @ 3c ambient) and my pumps are spinning 24/7.
Do I need to change the control unit when replacing my Ecodan Air Source Heat Pump
2 months ago
Mitsubishi Ecodan not good enough ?
5 months ago
6 months ago
Mitsubishi Ecodan circulation pump running.
7 months ago
Ecodan Auto Adapt Options
7 months ago
- 2,794 Topics
- 66 K Posts
- 3,864 Online
- 7,196 Members
Years ago I worked for a company who won a best in show...
By EtchedPixels , 7 hours ago
Has anyone here had a Cosy 12 installed yet?
By Mars , 9 hours ago
But looking at your graphs, why are your LWT and RWT cy...
By Temperature_Gradient , 9 hours ago
Not quite, regular A2W heat-pumps need a load of extra ...
By Temperature_Gradient , 1 day ago
one thing i learnt from reading people’s comments and e...
RE: Cooling/heating with one unit
"The way we use A2A on a cheap overnight EV tariff is t...
By mrkfm , 1 day ago
RE: Do I add Air Con or MVHR to existing A2W ASHP?
We have ‘signed on the dotted line’ today for a Panason...
...or it was there and was lost thanks to laziness and ...
@bobflux Thank you for your response. I am trying to ...
By RonV. , 2 days ago
This post is about how I successfully configured a buff...
By Tony.Stolz , 2 days ago
The installer visited yesterday and suggested the noise...
By JamesChatz , 2 days ago
RE: HeatGeek vs Octopus surveys: puzzling disparity - any ideas why?
Your house sounds a lot like mine. 2 surveyors each sp...
Thats true only if you do the wrong experiment. Done c...
As of October 1st they need specific qualifications to ...
By EtchedPixels , 2 days ago
