Samsung heat pump has arrived with damaged fins – do I accept it or send it back?
Hello everyone,
I have just had this Samsung heat pump delivered. It has been hit on the fins. Will it be ok or should I reject it?
I'm only a layman but I'd personally reject it given there's no way of knowing for sure what other consequences there may have been to the impact that caused the damage you can see.
I completely agree with @majordennisbloodnok – I’d send it back. While a few bent fins are common and often dismissed as insignificant by installers and manufacturers, the dent in your photos looks more substantial. Some installers have "combs" that they use to straighten them, but why take the risk? It’ll be interesting to hear what your installers have to say if you decide to return it.
did it arrive like that as I can see banding around it or was it in a box and someone has un-packet it and discovered the coil fin damage?
Damage is cosmetic is appears, but the result of poor handling, so there could be inner damage unseen. Send it back. I've noticed an increasing trend for ASHP OEMs not to have any protective guards on the coil inlet face. Removable guards used to be standard, but I guess its added cost for the manufacturer.
- 2,118 Topics
- 46.6 K Posts
- 38 Online
- 4,523 Members
@robl • Manufactured from Rehau white PVCu profiles of...
By Toodles , 38 minutes ago
@adamk You need this or at least this if you have...
By ASHP-BOBBA , 41 minutes ago
By Mars , 20 hours ago
By JamesPa , 24 hours ago
By Transparent , 1 day ago
By normpang , 1 day ago
By ASHP-BOBBA , 2 days ago
By Burtis , 6 days ago
By Old_Scientist , 6 days ago
By Lucia , 7 days ago
By Lucia , 1 week ago
By Ashfp , 1 week ago
