Cooling with Samsung Gen6 and Flow error
HI
I've got a Samsung gen6 ASHP, which I am trying to use for cooling. I have a large Harnitek fan assisted radiator in my main living room. Whenever I put the cooling on after about an 40 mins I get the e911 flow error.
I've checked the flow sensor its working fine, and on a cooler day a few weeks ago I put the heating on for a couple of hours and it works fine. So is this a pump problem, is it struggling due to the cold water and increase viscosity, thus can't pump it round effectively. Maybe a pump with bigger head would help?
Any thoughts would be much appreciated?
Samsung Gen6 8kw ASHP in a two bed victorian mid terrace.
I see that these fan coil radiators either come with a two-way or three-way control valve built into them. What does the valve do? Well from a quick read of yhe operator instructions, it appears the control board can close off the valve in certain preset conditions (e.g. timer mode).
I suggest you look into your fan coil units (radiator) operator parameters to see what the current settings are. I take it that you are selecting cooling mode on the radiator as well as the ashp?
@iaack I've got cooling mode on the radiator selected, and I've disabled the valve mode on it, so they are open all the time.
@ecobaker I'm still thinking that something is triggering the valve to close.
In cooling mode on the rad, what are you setting as the rad target temperature? What is the typical room temperature and water flow temp. when the problem occurs?
Is the condensate outlet clear? Air cond units have float switches to monitor the condensate level and can shutdown the cooling function if they detect an unusual rise in condensate level.
@iaack The system isnt running long enough for any condensation buildup, also I've got the flow temp set above the current due point temp. I don't think its the radiator
- 2,417 Topics
- 54.8 K Posts
- 269 Online
- 6,096 Members
So, after much anguish, and even visiting the neighbour...
By razz , 3 hours ago
MLCP (Multi-Layer Composite Pipe) for ASHP
@editor nope. The info you reported was sufficient for ...
By iotum , 5 hours ago
@robs Quick response while I'm in stationary traffic le...
By Sheriff Fatman , 5 hours ago
Maths looks right to me, my only question about this ca...
By JamesPa , 6 hours ago
RE: Ideal HP290 14kW ASHP - how to optimise
@jamespa I wasn’t offended at all. You are very knowled...
By Davesoa , 6 hours ago
RE: Experience - New Build / Complete New Heating System
@vincro I would be surprised if it is much above 5 to 6...
By ASHP-BOBBA , 6 hours ago
Yes, certainly not enough could have been tested in any...
By Batpred , 7 hours ago
RE: Post-Traumatic Heat Pump Stress Disorder
Yes bang on and maybe I can illustrate that by way of e...
By iotum , 9 hours ago
RE: Replacing my 18 month old Hitachi Yutaki ASHP
A big thank you to @jamespa for all his efforts online ...
By trebor12345 , 12 hours ago
RE: GSHP WOES! Midland based engineer recommendations?
@editor It is indeed for servicing. My current service ...
By Morgan , 12 hours ago
RE: Sunsynk Whole House Backup Issue
Hi @lostandconfused , I agree that topic/thread is the ...
By Batpred , 13 hours ago
RE: Speedcomfort radiator fans
In case it helps Andrew Kuhne on openenergy monitor has...
By JamesPa , 13 hours ago
Things have gone quiet with you @drei. Any updates?
By Mars , 16 hours ago
Thanks @tim441. Interesting timing, as Passiv are a cur...
By Mars , 18 hours ago
Hi everyone, I have a two year old Marlec Solar iBoos...
By Tallmarc , 21 hours ago
RE: Please help with the settings ecodan
Are you trying to address any particular performance is...
By Sheriff Fatman , 1 day ago
🤣 Well, I never managed to get the HA solis "...
