ASHP Ecodan L9 error - No Heating but Hot Water
@phoenix15 I hope you have success with finding a Mitsubishi accredited engineer very soon. Esp. If you have a leak as well.
it may be that over time you may have lost the rust inhibitor that stops the rust deposits build up. So if the plan is to flush your system that should mean you’ll get a fresh dose of inhibitor.
best of luck @phoenix15. Let us know how you get on?!
@phoenix15 Mars has a list of reliable ASHP companies, I assume this would not only be for installation but all services relating.
Where in the country are you?
@ashp-bobba Cumbria.. we have contacted the local ones we could find. Getting them to actually turn up seems to be the problem!
@phoenix15 Sorry to hear that, we are all the way down in Kent and we only cover Kent otherwise I would send you someone to help.
@phoenix15, @heacol cover your area… I’d strongly recommend you send Brendon an email: info@heacol.co.uk
- 16 Online
By Scalextrix , 9 hours ago
By HCas , 11 hours ago
By GrahamF , 14 hours ago
By immunity , 16 hours ago
By JamesPa , 21 hours ago
Just done your survey!
By Judith , 1 day ago
By Tasos , 1 day ago
By Scalextrix , 2 days ago
By bontwoody , 3 days ago
By Alex , 4 days ago
By GrahamF , 4 days ago
By DREI , 4 days ago
By Profzarkov , 4 days ago
