[Sticky] Air source heat pump roll call – what heat pump brand and model do you have?
11.2kW Ecodan
Manufacturer: Misubishi
Model: PUZ-WM112VAA
Type: ASHP
Arrangement: Mono
Area of Country: Midlands
Home Type: House - detached
Size: Square Metres: 149
Insulation Level: Maybe a 6/10? Built 1955 with a foot of insulation in the loft, double glazing, somewhat degraded cavity insulation
Heat Loss Calculation: 8.79kW at -2.9C
Type of Controller: Ecodan
Type of Control: Weather compensation, Ecodan FTC7 remote thermostat/controller
System Type: Radiators
Total Output of Heat Emitters: heat loss 8.79kW, avg heat load 59W/m2
Buffer Tank or Low Loss Header: Buffer tank
Secondary Pumps: 0
Solar PV System: 8 panels >10 years old
Power Diverter: No
Battery System: No
16Kw AIROSD
Manufacturer: Foshan
Model:
QBKFXFC-016SRIType: ASHP
Arrangement: Mono
Area of Country: South Lancashire
Size: Square Metres: 220
Insulation Level: Maybe a 6/10? Older part built early 1800's, single wall construction, originally 2 cottages knocked into one in 1970's. Left hand side of house (LHS) and right hand side (RHS)extended in to 1970's with building regs of the day. New extension 2010 insulated cavity walls. Radiators to older part of the house, all changed to type 22. UFH to ground floor of extension 60 square metres and radiators to master bedroom upstairs. Double glazing throughout. Insulation to 300mm in loft.
Heat Loss Calculation: Not known
Type of Controller: Airosd
Type of Control: Can manually control return water temp to give a delta T of 4 degrees.
System Type: Radiators to older part and UFH to ground floor extension
Total Output of Heat Emitters: Not known
Buffer Tank or Low Loss Header: No
Secondary Pumps: 3, one to UFH manifold, one to LHS and one to RHS all set at speed 1. Mainpump from ASHP set at highest constant pressure curve.
Solar PV System: 10 panels
Power Diverter: Solar iboost
Battery System: No
Forum Handle: KevB
Manufacturer: Ideal
Model: 5kW
Type: ASHP
Arrangement: Mono
Area of Country: South England
Home Type: House
Size: Square Metres: 91m2
Insulation Level: 5? 1980 built. Cavity insulation, double glazing
Heat Loss Calculation: 4.8kW @ Amb. Temp, of: -2c
Type of Controller: weather comp with room influence. 1 thermostat (Halo) and TRVs but all fully open.
Total Output of Heat Emitters: 5kW
Buffer Tank or Low Loss Header: BT (do have a bypass but not used)
Secondary Pumps: 1
Solar PV System: no
Power Diverter: no
Battery System: no
Forum Handle: @lucia
Manufacturer: Daikin
Model: EDLA06EV3
Type: ASHP
Arrangement: Monobloc
Region: SWest
Home type: Bungalow but hill built
Size: 98 sqm approx (+ cellar)
Insulation level: 1970s/80 built; partial cavity filler; good loft insulation; ancient windows; suspended floor/cellar not yet.
Heat loss: 4.8kw @ -3 but some things not accounted - eg cellar; exposed location;
Type of Controller: No thermostat - strictly leaving water temp control and weather curve. TRVs fully open
System type: radiators (all new)
Total output of emitters: ?
Buffer tank: No. Low loss header
Secondary pumps: no
Solar PV: no
Diverter: no
Battery: no
Forum Handle: @davec
Manufacturer: Peak Energy
Model: 11kW V-Therm S-Maxi
Type: ASHP
Area of Country: North West England
Home Type: House, semi-detached
Size: Square Metres: 122m2
Insulation level: loft insulation, some suspended floor insulation, no cavity insulation
Heat Loss Calculation: 7kW @ Amb. Temp, of: -2C
Type of Controller: external EPH Thermostat, each radiator with TRV
Type of Control: Weather Compensation, Flow Temperature, Room Temperature via EPH thermostat
Total Output of Heat Emitters: 11 triple column radiators and 2 towel rail radiators
Buffer Tank or Low Loss Header: BT, I think built in to the water cylinder
Secondary Pumps: No
Solar PV System: SunSynk 3.6kW Inverter with 3.5kWh panels
Power Diverter: Yes solar diverter, but switched off
Battery System: 10kWh house battery
11kw Peak Energy ASHP - SunSynk 3.6kW Solar Inverter with 3.5kw panels and GSL 10kWh home battery
Forum Handle: PickStick2804
Manufacturer: Worcester Bosch Compress AWF2000 10kW (Midea)
Model:Compress AWF2000 10kW (Midea Clone)
Type: ASHP
Area of Country: Yorkshire
Home Type: House
Size: Square Metres: 270
Insulation Level: 9 High
Type of Controller: Standard controller + Svenar RS485 into Home Assistant. Shelly EM power monitoring on ASHP and Immersion.
Type of Control: Weather Compensation (42@-5, 31@7) at £0.28p 0530:2330, aggressive curve 1 (55@-5, 54@7) at 7p 2330 to 0530. (just set this up as I type, I may have been cooked by morning)
System Type: UFH (solid slab on ground floor, between timber joists on 1st floor)
Buffer Tank or Low Loss Header: None
Secondary Pumps: 2 UFH Manifolds with Pump on each, actuators removed, flow balancing valves by room.
Solar PV System: No
Power Diverter: Yes - MyEnergi Eddi
Battery System: No
All primary flow & return pipe 28mm with long radius bends or 45s where possible. Armacell 25mm insulation inside - Primary Pro insulation outside. Antifreeze valves, no glycol.
279L Unvented indirect cylinder with 2.96m2 coil
Geek level 11.
Forum Handle: MK4
Manufacturer: Midea
Model: M Thermal Arctic HT Series 16Kw using R290 MCH-V16WD2RN7
Type: ASHP
Arrangement: Mono
Area of Country: Northern suburb of Athens, Greece (Municipality of Dionysos)
Home Type: House dettached
Size: Square Metres: 240
Insulation Level: 1983 partial 5cm cavity glass wool, 2022 external 10cm rock wool, double glazing
Heat Loss Calculation: 13.3kw @ Amb. Temp, of: -7C
Type of Controller: Midea wired controller using weather compensation
Total Output of Heat Emitters: 42kw nominal value at 70/60/20
Buffer Tank or Low Loss Header: NO
Secondary Pumps: 0
Solar PV System: YES
Power Diverter: NO
Battery System: YES
Model: EDLA04E2V3 (4Kw)
Type: ASHP
Arrangement: Mono
Area of Country: East Anglia
Size: Square Metres: 150
Insulation Level: 8/10
Heat Loss Calculation: kW @ Amb. Temp, of: 4.1kW at -3C
Type of Controller: Pure LWT control
Type of Control: Weather compensating
System Type: Radiators upstairs and UFH downstairs
Total Output of Heat Emitters: n/a
Secondary Pumps: 0
Solar PV System: 4.5Kwp
Power Diverter: No
Battery System: 19.5 Kwh
Installed 1st of August 2025, COP for Jan-26, Heating only: 3.53
@georgea Sounds like you have a good low-cost-to-run efficient system there. The absence of an LLH and secondary pump has to be good too! Hope it all continues to provide the comfort you require. Regards, Toodles.
Forum Handel @jancold
Model: EDLA06E2V3
Type: ASHP
Region: SWest coastal
Home type: Semi detached
Insulation level: 1926 cavity filled; good loft insulation; Double glazed windows; suspended floor, uninsulated
Heat loss: 5.8kw @-2C
Type of Controller: leaving water temp control and weather curve. TRVs Bedrooms only
Buffer tank: Volumiser
Secondary pumps:
Solar PV:
Diverter:
Battery: Solis 8KW Inverter with Fogstar 2* 16KWh
Daikin 6Kw ASHP.
- 2,475 Topics
- 56.9 K Posts
- 363 Online
- 6,165 Members
By errmm , 4 hours ago
By JamesPa , 5 hours ago
By JamesPa , 6 hours ago
By DavidB , 7 hours ago
By CraigH , 8 hours ago
By Rusty , 8 hours ago
By Mars , 8 hours ago
By AndrewJ , 9 hours ago
By Batpred , 11 hours ago
By Toodles , 11 hours ago
By Papahuhu , 12 hours ago
By Batpred , 13 hours ago
By Gruff2001 , 13 hours ago
By Steelbadger , 1 day ago
By Jancold , 1 day ago
By L2jad , 1 day ago
