Advice for a novice...
Advice for a novice on Mitsubishi Ecodan 6kW
7 Users
9 Reactions
 F1p
(@f1p)
@sheriff-fatman
It appears Output Power = 0kW because there was a DeltaT of 0
Which doesn't appear correct because it was 4C according to the data.
Like you say, i presume this is a timing/capture thing, in particular with the Home Assistant firmware which has different refresh rates for different parameters giving higher resolution when viewed there.
Just a note on the Thermo. Diff setting - it only applies in Auto Adapt. It appears you are in Compensation and therefore overshoot is only +1.0
This is the classic Flow Temp overshooting Flow Setpoint issue
The Ecodan was initially set to a +5/-5 tolerance, which is it's default option.  I've subsequently adjusted this to +3/-7, but it still works around a 10°C tolerance around the flow temperature currently.
This post was modified 2 hours ago by F1p
 F1p
(@f1p)
I wonder, @sheriff-fatman, if Mitsi have chosen to use a shared parameter between defrost cycle and freeze protection. If that were the case, we’d see a software-induced correlation rather than a physics correlation, but a correlation nonetheless.
“Curiouser and curiouser”, said Alice…
Frost Protect/Freeze Stat is an operation mode, where Defrost is a multi-stage status flag (however i only see two used).
In the firmware i inject defrosts to the Operation Mode status for easier viewing and understanding of users.
Page 4 / 4
