If I had a new ASHP installed I would still have to have a hot water cylinder. I watched the relevant video on this site. But I don't need any buffer unit.
Can I get clarification on this point.
Can the ASHP External unit, supply heat for Central Heating radiators or UFH at one temperature and one set of F&R pipes and do that supply directly? Bypassing the cylinder?
Or have I got that completely wrong and need to go away and do some serious reading? 🤔
Nothing like a government grant to bring out the bandits for sure. An absolute minefield and as per my other post our current installation is hardly going smoothly. The company we went with however were one of the few who didn't want a massive amount of money (in effect the whole cost of the job minus the grant) up front, so at least I have some leverage to try and ensure it is completed to a decent standard.
As for optimus heating, came across as knowing their onions but I booked an initial home survey after a fair bit of back and forth communications (mainly telling me how good they were) and after all that they didn't turn up or contact me to tell me they weren't coming. Red flag #7?
@benson Optimus didn't turn up?
@benson that's very disappointing indeed.
Posted by: @gt22Can the ASHP External unit, supply heat for Central Heating radiators or UFH at one temperature and one set of F&R pipes and do that supply directly? Bypassing the cylinder?
ASHPs (and fossil boilers running at a low flow temperature or with weather compensation - rare in UK, common in more enlightened countries) supply at one flow temperature at any one time and thus the installation will invariably include a three way diverter valve (or two two way valves) so that space heating or dhw can be fed, but not at the same time. The unit switches flow temperature and the diverter valve according to whether space of dhw heating is required.
If you need, in addition, two flow temperatures for space heating you must supply the space heating at the higher temperature and mix down for the lower. Again same for boilers and ASHPs. The ASHP COP will be determined by the higher, because that is the temperature it is required to produce.
Hope that clears matters up.
Posted by: @gt22
@jamespa Many thanks. You are adding to my education on the current ASHP approach. So different from my 2009 Sanyo configuration, hence my questions.
My ashp journey is only 3 years old and in that time it's clear that thinking has matured quite significantly, albeit by no means universally. I can only imagine how much change there might have been since 2009.
Please continue to ask questions, people here are very willing to help and no question is silly.
Great article! You've highlighted essential red flags to watch out for when considering a heat pump installation. One innovative idea would be to include tips on how to verify the credentials of installers, ensuring both quality and reliability in the installation process. Keep up the informative work!
@mars That could be a whole discussion in itself. I don't personally think its simple!
- 2,122 Topics
- 46.6 K Posts
- 74 Online
- 4,529 Members
There are some projects looking at how smart meters and...
By Jeff , 5 hours ago
@terry1812 Yes, I use Homely, as to whether Daikin is u...
By Toodles , 17 hours ago
By cathodeRay , 22 hours ago
By Toodles , 1 day ago
By Judith , 1 day ago
By JulianC , 2 days ago
By Judith , 2 days ago
By TRBob , 3 days ago
By Toodles , 4 days ago
By Mars , 5 days ago
By JamesPa , 5 days ago
By Transparent , 5 days ago
