Battery...Full house back up
One detail that you may want to consider is the warranty on the battery. I recall that the warranty (minimum 70% storage capacity aftre 10 years) for the Powerwall 2 was conditional on the the total energy throughput which worked out to be one full charge / discharge cycle per day. However, if your anticipated 2.5 charge/discharge cycles per day is the worst case then this may average out to nearer unity over a year.
Well I'm pleased to see you doing the background research first @broadsman !
I can assist with the technical issues, but none of us can adequately predict the future tariffs on which you are building your viability assessment.
I have a fair idea of how future tariffs should work over the next 5-years as the electricity grid is decarbonised.
But both DESNZ and Ofgem have been demonstrating a propensity to manipulate the electricity supply system by 'regulations' rather than the laws of physics.
Yes, there will still be frequent cheap-rate periods, but they will be less regular.
The overnight cheap-rate can't survive because it's based on Combined Cycle Gas Turbine (CCGT) generation, for example.
Turning briefly to the matter of a Tesla PowerWall-3:
These Powerwalls vary considerably from the 1st generation which used the same LiMNC chemistry as Tesla cars.
The Lithium Ferrous Phosphate (LiFePO4) chemistry is inherently more stable and can be recharged more often for a given 'loss of capacity'.
However, it's very difficult to assess this because each LiFePO4 cell manufacturer uses a different standard.
Typically they will state something like "10,000 charge/discharge cycles over its lifetime".
But the 'lifetime' might be to 70% of the original stated capacity (in Amp-hours)
or 80% of the actual capacity when first supplied.
These are two different concepts.
All cell manufacturers sell products with a higher actual capacity than that which is advertised.
A cell labelled 280Ah, might actually have 298Ah.
The 280Ah refers to the minimum capacity, in order to satisfy its A-grade rating and trading standards legislation.
Equally, households with battery storage aren't very likely to put those cells through complete charge/discharge cycles.
Most of the time we'll be using only the central portion of the available capacity, whilst leaving enough in reserve to ride-out a power-cut.
So our cells won't 'age' as fast.
Have you seen the YouTube clip in this post about the new battery/inverter products to be released by Givenergy this year?
It's not the approach which I'm taking, but it's certainly one which might appeal to you.
- 2,153 Topics
- 47.3 K Posts
- 17 Online
- 5,673 Members
By ASHP-BOBBA , 2 hours ago
@pash44pump what we did to resolve a not too dissimilar...
By benson , 4 hours ago
My Samsung Gen6 (probably same controller as yours) onl...
By Old_Scientist , 12 hours ago
By JamesPa , 12 hours ago
By Old_Scientist , 14 hours ago
@rob-nezard you can see more of Drei's rad dramas here ...
By Mars , 14 hours ago
@drei I will say again that Im sorry to heat about your...
By JamesPa , 15 hours ago
By DREI , 1 day ago
1040kw Even beat June and July. Great month.
By Andris , 1 day ago
Hope they know what they're doing regarding paint types...
By PatrickVito , 1 day ago
By Toodles , 1 day ago
@bontwoody Maybe one for @editor to consider whether a ...
By ChandyKris , 2 days ago
@mars That response surely deserves a nomination for Tu...
Specifying batteries, pv solar etc using ChatGPT
I thought I'd try to use ChatGPT to specify my requirem...
By Tim441 , 2 days ago
When I interviewed Mitsubishi Electric at Installer ear...
@lucia One look at that protection and the rodents will...
