Vaillant & OVO partner up to offer Heat Pump Plus
@johnmo not how far this goes to answer your question but… in the EV tariff they can turn on & off your EV charger.
Posted by: @westkent@johnmo not how far this goes to answer your question but… in the EV tariff they can turn on & off your EV charger.
Slippery slope starting
Posted by: @AnonymousPosted by: @ecodan-efficiencyPosted by: @toodles@ecodan-efficiency Octopus Energy offer ‘Cosy’ for heat pump owners. You supply them with your MCS registration to qualify. Regards, Toodles.
I guess what I mean is are OVO the only ones collecting ASHP energy use data and using it to bill against?
And will they be the first to use the smart grid switch that most current heat pumps have, to switch the ASHP off when it suits them and the grid demands?
If they are directly collecting data from the heat pump, are you sure the data stream isn't two way?
They don't at the moment at least. They just pull data from some API that has been given to them by, in this case, Mitsubishi once a month. It doesn't sound terribly sophisticated. Given the numbers on the tariff it could even just be an emailed spreadsheet!
Who knows what the future will bring, but given Mitsubishi's cloud software is so basic and never seems to get updated (although at least it works) I can't see it happening any time soon!
@ecodan-efficiency On the other hand, the fact that the Mitsubishi cloud software is "stable" could be a benefit in that Ovo will not be constantly changing whatever interface they have. My concern is that I hear that the data provided by Mel-Cloud is not fully accurate so that would presumably affect the accuracy of the billing.
Install 13 April 2024 - 4 Bedroom Brick Detached - Heat Loss 9,281w, Design 45c at -2 - Ecodan 11.2kw R32 - 25L Buffer - 250L Telford Tempest HP DHW - All 16 radiators replaced - Auto Adapt - Mel-Pump app - Octopus Fixed Rate
- 2,114 Topics
- 46.4 K Posts
- 47 Online
- 3,410 Members
Delighted to hear this went well. It looks very neat ...
By JamesPa , 7 hours ago
The issue with the Grant is that you have to wire direc...
By Grantmethestrength , 11 hours ago
By Toodles , 11 hours ago
By Brendon Uys , 16 hours ago
By Burtis , 1 day ago
By trebor12345 , 2 days ago
By Lucia , 2 days ago
By Ashfp , 3 days ago
By Mars , 6 days ago
By Prunus , 6 days ago
By Mars , 7 days ago
