Never understood the need for three phase in a domestic situation. Even with an electric car, you charge slowly overnight doesn't need rapid charge.
Larger heat pumps, heated pools, steam rooms and hot tubs in top of a normal domestic load were examples that came up today. I had a three phase supply in my childhood home but that was because we had a kiln - so not a normal domestic load!
Posted by: @gunboatdiplomatLarger heat pumps, heated pools, steam rooms and hot tubs in top of a normal domestic load were examples that came up today. I had a three phase supply in my childhood home but that was because we had a kiln - so not a normal domestic load!
Please correct me if I am wrong, but I was under the impression that the objective was to save our planet from global warming by using LESS energy.
Posted by: @gunboatdiplomatchildhood home
Mine had coal fire, doesn't mean I would have one now.
If your home is listed as grade 1 then you have a plausible excuse for a very large heat pump, otherwise get more insulation, reduced drafts.
Pools should be heated by a heat pump, so they can be very small anyway.
So still see no need for 3 phase.
@derek-m Well, preferably no dirty energy and only as much clean energy as might be justified. As the King who had to cut down on his staff is reputed to have said ‘Can’t a King have a biscuit?😉 Toodles.
@derek-m That''s the irony of electric vehicles isn't it? Being heavier than ICE ones they need more energy to move around. The extra energy needs to be from renewable sources for them to make sense.
Mike
@mike-patrick I think the 745.7 watts of renewable energy required for the electric vehicle is probably a more efficient horsepower than one derived from a probably less efficient ICE in a vehicle? (What I’m trying to say is: I don’t know the efficiency of an ICE!) Regards, Toodles
Very roughly speaking, a modern ICE vehicle is up to about 25% efficient whilst a comparable EV is about 75% efficient. The EV then has an extra complication that there are losses of between 5 and 10% in the charging process itself, but that still makes for a hugely more energy efficient vehicle despite the heavier weight.
@majordennisbloodnok Thank you for confirming my thoughts Major. Regards, Toodle.
@mike-patrick Actually Mike, my BMW i3 is lighter than an equivalent ICE car, much to my friends annoyance when he was trying make a point about EV weights, so its not a given.
However the real advantage of EVs over ICEs is regenerative breaking where most of the energy that is just lost in slowing down an ICE is recouped back into the battery in an EV.
That is a major area where EVs increase their efficiency over ICEs as well as in the conversion process where ICEs are very poor efficiency.
- 13 Online
By Scalextrix , 11 hours ago
By HCas , 13 hours ago
By GrahamF , 16 hours ago
By immunity , 18 hours ago
By JamesPa , 23 hours ago
Just done your survey!
By Judith , 1 day ago
By Tasos , 2 days ago
By Scalextrix , 3 days ago
By bontwoody , 4 days ago
By Alex , 4 days ago
By GrahamF , 4 days ago
By DREI , 4 days ago
By Profzarkov , 4 days ago
