Are there any compa...
Are there any comparisons of DHW heat stores around?
4 Users
0 Reactions
(@sarahemmm)
New Member Member
Topic starter   [#3207]
I'm now starting to look for a replacement for my gas combi to provide DHW. I already have two A2A multipoint installations for heating/cooling, although I have currently left the radiatior system in place. Unfortunately no PV, as the roof is not suitable.
I've been looking at the Sunamp (thanks, Toodles, for all your information!) but I'm wondering what else is out there and how they compare.
Obviously this is not urgent, as the combi is relatively new and can stay in place until it fails or we run out of gas...
(@etchedpixels)
Mine is partly still on gas and partly tanked and tank + good old immersion element on EV tariff made the RoI on other solutions nonsensical on current tariffs.
The last house I've been helping do up has an old fashioned power shower and for the water usage expected that also beat bothering with fancy technology. The up front cost of a lot of these systems is surprisingly large for what you get in return versus just accepting that water is expensive to heat. I guess it works if you use a lot of water.
For most people it's a non-issue, just look how few of them connect the optional hot line on their washing machine to the heatpump water tank 8)
One thing to note if you don't already know - you need to keep some radiators in place to use the combi for hot water only. When you turn the hot tap off it dumps some heat into the radiator side in order to get rid of it.
(@sarahemmm)
New Member Member
@etchedpixels
Since I was encouraged to move to a combi over 20 years ago, I no longer have a HW tank, and the CW tank was removed too. So no options for an immersion (though I do have immersion wands in the bathroom rads now).
Its a long time since I saw a washing machine with H+C feeds - they are almost always cold only.
And, yes I do realise that the combi needs some rads. Right now it is happily working away, but as I say, in the fullness of time it will go. This will be our third winter with aircon, and we are very happy with it, but just at present it seems sensible to use the rads while gas is available and cheap. One of the joys is that we can just increase the heat in one room without the expense of heating the whole house, which is great for working from home.
Posted by: @sarahemmm
If you have a good ToU tarrif and an existing immersion heater, it will take a long while to pay back relative to just using that!
@sarahemmm I have done things the opposite way round I suppose, though I have solar panels as of 4 years or so ago, I had a gas boiler but not a combi. BG had fitted a replacement DHW cylinder for us and this was large enough for our needs though only 99 litres. When we came to the ASHP installation, there really was no suitable space for the MCS recommended capacity of 210 litres as, strictly speaking, ours is a 4 bedroom house. The Sunamp was a really good solution and powered solely from the solar array for a large proportion of the year, works well for us and still leaves airing cupboard space. It really is ‘horses for courses’ and had we had a combi gas boiler, we might well have run a different race. Regards, Toodles.
