- 2,391 Topics
- 54.2 K Posts
- 159 Online
- 6,074 Members
RE: Hot water heating in parallel with space heating
That sounds like an interesting idea. Coil sizes would ...
By bontwoody , 14 minutes ago
@wally can I just check the obvious- the kWh usage you'...
By benson , 5 hours ago
The Solis has an export limitation feature. This was ac...
By Batpred , 6 hours ago
RE: Heat pump not reaching flow temperature
@johnd, what you’re experiencing is common with air sou...
By Mars , 9 hours ago
RE: Gen 6 Samsung ASHP losing 20C of DHW in 60 min directly after generation
@ecobaker Thanks for this. I've had it in both slots. ...
By andbeck , 9 hours ago
RE: Air source heat pump circuit not operational
Welcome to the forums. If the thermostat shows it’s c...
RE: Daikin Atherma ASHP Cycling 6 Times an Hour?
From what you describe, it sounds like you’ve done a so...
Of course it is not helpful to frogstar fan club member...
By Batpred , 11 hours ago
RE: Ecodan with FTC7 - True Weather Compensation
@danwright90 I've linked two videos below recorded this...
By Sheriff Fatman , 11 hours ago
@steelbadger, I’ve pretty much decided now that there’s...
By Majordennisbloodnok , 12 hours ago
That makes plenty of sense. Perhaps more importantly, O...
By Majordennisbloodnok , 13 hours ago
It does but it almost all applies to boiler systems and...
By JamesPa , 16 hours ago
RE: Installer Fitted 9kW Instead of 11kW Heat Pump and Changed MCS Paperwork - What do I do?
So theres a problem for starters. This means that the ...
By JamesPa , 17 hours ago
RE: Insulating a pitched roof with kingspan, has anyone done it?
Thank you everyone for all of the information, it looks...
By TRBob , 1 day ago
@transparent Yep, they didn’t even mention it. When ...
They are lovely, and I feel lucky to live in one, but t...
Worth adding that, for this tariff, the Octopus app has...
RE: APP for remote Daikin ASHP Operation
Thanks, @newhouse87. Understood. I was only asking on...
@mike-patrick A propos, I think my heat pump generates ...
By dr_dongle , 2 days ago
