Post Buffer Tank DU...
Post Buffer Tank DUCA Circulating Pump Settings
2 Users
2 Reactions
(@potatoman)
Does anybody know what is the best setting to have your heat pump, post buffer tank circulating pump set to, there are 5 settings: iPMW, AUTO, PP, CP & CS.
This topic was modified 1 year ago 2 times by Mars
Could you post a photo? Is it a Grundfos?
(@potatoman)
@editor  Hi, it is a DUCA
pump
@potatoman I raised this with Secon, and here's what they say:
"If you have a PWM connection then leave it in PWM. If not, auto is always safe. If it's a particularly long pipe run, you might need constant pressure (CP) maximum speed."
Does that help?
(@potatoman)
@editor Hi, yes it does, thank you
