Solcast thoughts.....
2 Users
1 Reactions
TechnoGeek
(@technogeek)
I have just had a new solar array and batteries installed in the last week and have the option to sign up to Solcast for my PV array.
Does anybody use their service and what are your thoughts? Any good, is it worth it?
I believe they do a free account for home owners with limited features but are these features enough to get the best out of your PV array?
Regards
Bivalent system containing:
4.1Kw Solar Panel Array
(@majordennisbloodnok)
Of the various solar PV forecasting services, Solcast seems to have been found to be the most accurate. However, whether it’s worth using is a hugely different matter. Do you have any idea of how you want to use it?
Solcast is also closely linked with the Home Assistant addon called Predbat (or Batpred). I looked into this and decided what it provides does make a financial difference, but I get almost the same benefit from a couple of basic Home Assistant automations that fill the battery enough to tide over the Agile expensive times, and that doesn’t need any forecasting at all.
For me and my situation, any forecast costing more than zero pence is too expensive.
TechnoGeek
(@technogeek)
@majordennisbloodnok thanks for your thoughts.
My initial strategy is to fill the batteries with cheap power overnight during Winter but leave enough space in the batteries overnight before a day of solar availability. Summer time it is a little easier to predict I think plus I only need to ensure the batteries are a 1/3 full in summer as the heat pump will be off so a lot more flexibility regarding solar charge.
Regards
Understood, @technogeek. I can’t remember; do you use Home Assistant or not?
TechnoGeek
(@technogeek)
No I do not. It seems the GivEnergy portal can speak directly to the Solcast API so Home Assistant in this case, may not be needed.
Regards
In that case, @technogeek, I’d sign up for the free solcast account and see how you get on with it. Alternatively, play about with scheduling to a 65% state of charge overnight and see how well it works without any forecast at all.
TechnoGeek
(@technogeek)
@majordennisbloodnok I have decided to take the plunge.
Added my electricity account access to my system so it could get tariff pricing at various parts of the day and added the Solcast account. It appears the GivEnergy system then takes over the day to day battery management.
It looks like it uses algorithms to analyse your previous usage and the predicted solar forecast to decide how much power to import ( in my case ) overnight and leave enough capacity for solar charging.
Will let it run for a couple of weeks after I have got the loss factor correctly set and report back on how I got on with it. It looks promising on first impressions.
Regards
TechnoGeek
(@technogeek)
@majordennisbloodnok it has been a few weeks since adding the Solcast portal so reporting back as promised.
After correctly setting the PV array azimuth and incline together with the system loss information in the Solcast model, I am pleased to conclude the Solcast forecasts are very accurate 🙂 and well worth using.
As an example, over the last 3 days it was estimated I would generate 6.23Kwh. My actual generation was 6Kwh
Solcast provide an API to enable someone to put a program together if their respective solar system / battery management software does not provide for integration to Solcast.
Regards
Thanks, @technogeek. Good to hear about the accuracy.
Currently, the only way I know of fully integrating Solcast into any automated charging using Home Assistant as the hub is by installing an addon called Predbat (aka Batpred). It’d be interesting to find out what other alternatives there may be to compare against.
