Say hello and intro...
265 Users
737 Reactions
262 K Views
(@majordennisbloodnok)
Posted by: @scalextrix
it's a question of the right tool for the right job.
Bog standard house (for it's era) with a few well documented changes = the standard heat loss measurement should be fine. The Elmhurst training does talk about alternatives for more complex scenarios
In a way, @scalextrix, you and @jamespa are talking about different points.
You’re quite right that one needs the right tool for the job. However, even the right tool needs to be used correctly.
Is there anything inherently wrong with the maths behind the heat loss survey process? Not as far as I’m aware. That means it could be one right tool for the job.
Is the heat loss survey “tool” used properly? De facto evidence is “no”; countless customers finding after the fact that their home was given a significantly pessimistic estimate demonstrates this.
How is the tool being used incorrectly? There are two gotchas. Firstly, surveyors make assumptions that have a large material effect on the outcome. That doesn’t mean the model is bad; merely that it can’t work with bad data. Secondly, the outcome - the estimated heat loss - isn’t routinely tested against the real world. Sometimes assumptions have to be made but that’s why you test where you can, and the industry standard is not to verify.
So your assertion is that the heat loss survey is a reasonable model. I agree.
@jamespa’s assertion is that the heat loss survey isn’t used properly. I agree.
It’s not the model that’s flawed; it’s the implementation. And until the survey process includes a bit that says to the surveyor “now cross-check your estimate”, it will remain flawed.
This post was modified 2 months ago by Majordennisbloodnok
This discussion has gone quite deep for our Hello & Welcome topic.
If you're new here, and still wondering whether to introduce yourself, then please do so.
There aren't that many problems we haven't been able to resolve one way or another
even if it's just a shoulder to cry on.
KleenexSsm
(@paultheheating)
im paultheheating am rural landlord and have heating problems
Hello @paultheheating - I'm a rural Moderator!
What's the heating problem?
In your house or a tenant's?
(We understand that diagnosing issues in a house lived in by a tenant is more difficult as you may not have open access.)
Page 108 / 108
