Ground source heat ...
Ground source heat pump is unaffordable to run
7 Users
6 Reactions
(@gshpwoes)
@hughf I don’t think the immersion is on?
IMG 2623
(@hughf)
@gshpwoes you can cancel the legionella program for a start. Total waste of time, unless you’re 85 and immunocompromised.
(@hughf)
Posted by: @gshpwoes
It certainly appears that way…. Although having your gshp on a c50 seems somewhat excessive. However, I expect it’s because it isn’t an inverter machine, a lot of older gshp weren’t. With that come quite a sharp startup surge when the compressor fires up.
Do you know the model number of the unit, the design flow temperature, and the heat loss calcs for the property?
@gshpwoes, which part of the country are you in?
(@gshpwoes)
@editor south east scotland
(@heacol)
@gshpwoes Unfortunately, from looking at the pictures, and the components used, you more than likely have a serious flow issue.
(@gshpwoes)
@heacol can I do anything about this?? 🤞
(@gshpwoes)
@heacol hoping you can advise if this is a fixable problem and if it is, how..? 🤞
@gshpwoes I received the following reply from the Heat Pump Federation directly relating to your case:
As the machine is nearly ten years old, it probably doesn't have very good Internet connectivity for remote diagnosis. If the homeowner wants to email the Federation with whatever design materials they have, we'll see what can be inferred, before sending someone along and incurring that sort of cost. For example, with the postcode, we could review the EPC (Scottish equivalent) and the geology, to get a feel for system sizing. The fact that the radiators are cold in parts suggests a balancing problem. That could be dealt with by a competent heating technician/engineer because distribution problems are common to all technologies to a large extent. So they could find a good local central heating provider to look at that bit of the system.
Apart from that, have you made any progress with your system?
@gshpwoes did you ever resolve your issues above?
Page 3 / 3
