Replacing Worcester...
Replacing Worcester oil boiler with an ASHP
27 Users
182 Reactions
36 K Views
JulianC
(@julianc)
Reporting performance details again.
MCS installer predicted electric demand of 2130kWh to date from installation in April.
Actual consumption is 1442kWh.
So that’s a good start.
Perhaps I need to put more effort into measuring efficiency. But my quality measurement is Mrs Jules saying the home seems warm 👍
As stated earlier, I intend to run the system for a year using the Nest wall thermostat and then switch over to the Daikin controlled heat curve and compare.
@julianc
Hi Julian,
what sort of daily kWh numbers have you been using lately?
Kev
JulianC
(@julianc)
35kWh yesterday. Average 30kWh per day in Dec
Average 19kWh/day in November.
And average 5.5kWh/day in October
Predicted was 13.8kWh in Oct, 31.6kWh in Nov and 50kWh/day in December. 54kWh/ day for January before it drops way
JulianC
(@julianc)
JulianC
(@julianc)
Warmer December so far means we are using less electric to heat home than predicted against MSC ASHP model. Namely 1638.11kWh consumed versus 2532kWh predicted. Good 👍
Posted by: @julianc
You don't believe anything MCS says do you? 🙄
JulianC
(@julianc)
@derek-m haha Derek of course 😂
But it is a good way for me to track actual costs
JulianC
(@julianc)
Took out the gold level Daikin ASHP support contract today. £264/year for 10 years. Fixed price. Including annual service, free parts, labour and call outs. Added cost, over and above the ASHP installation. But I think piece of mind. One of the reasons I chose Daikin over other vendors.
How much do other owners pay for an annual service?
(@alastair)
Hi @julianc
Happy New Year
It sounds like we are getting a similar set up to you - solar panels, Mixergy tank, Daikin heat pump and battery. In a previous house we had solar panels and a Mixergy tank and loved that set up. The battery seems to be a set and forget type of system, or at least easy to tweak through an app etc. The only component that I've no experience of is the Monobloc heat pump. I've done lots of homework, and am looking forward to having it, but I was wondering what your thoughts are on the actuality of living with your heat pump and the system overall. Does it just sit there and get on with it? Or do you need to tweak it a lot? I noticed that you needed to be sure that noise wasn't an issue - is that working out OK too?
Any pointers/thoughts would be great
Cheers
Alastair
JulianC
(@julianc)
@alastair Happy New Year. Similar systems (except your battery).
My Daikin ASHP is fit and forget really. We are doing a year using a Nest as the controller. I’ve set the heat to come on in the morning and gradually increase late in the day to 20.5C. Then off at night. Mixergy heats during my cheap Octopus night tariff. So I’m using the Daikin like the oil boiler it replaced. No tweaking.
So we’ve used much less electric than MCS predicted (but milder?). 1900kWh used vs 3100kWh predicted. And my wife says our home is warm. So result.
Once the trial year is up, I intend to switch to using the Daikin heat compensation curve. And do another comparison.
4
(@alastair)
@julianc Thanks for that response. Great to know how you are using it and that you are using less energy than predicted too. 🙂
JulianC
(@julianc)
F8D145F5 5FC4 45D2 9C01 421787FE2BCF
A4832638 3C9E 49FC 9A0E 5E8B8578E067
097DAFB9 888A 4397 BDC6 D1357C60B559
Was outside as my Daikin went into reverse/defrost cycle. Here is a photo of the start. And the steam/water vapour being cleared as the process nearer the end. Took 9 minutes. At 1 or 2 C. Home stayed warm. But COP must be impacted. I’d not really seen before.
Page 10 / 16
