Winter climatic curves v Spring/Autumn climatic curves
We have a Grant Aerona3 and are trying to tweak our cliamtic curves after discovering our installer had set them to just heat the radiators at max and burn holes in our pockets. Should you expect to tweak the curves during the year and thus have different settings in winter compared to spring or autumn or is it OK to keep the same settings all year?
Posted by: @davidm06We have a Grant Aerona3 and are trying to tweak our cliamtic curves after discovering our installer had set them to just heat the radiators at max and burn holes in our pockets. Should you expect to tweak the curves during the year and thus have different settings in winter compared to spring or autumn or is it OK to keep the same settings all year?
Very sensible (you, not your installer).
I suggest (if you haven't already) you set any TRVs to well above the desired temperature and any thermostat ditto, so you get the WC curve to as low as possible. You will hopefully want to leave most there so control is essentially by WC alone. Heat pump on 24*7 I hope.
The theory is that the settings should be the same all year if you get it right at both ends. Of course its difficult to adjust the 'high OAT' end until we get milder weather, so in practice you might have to iterate a bit. Currently its a bit intermediate so you might find you need to tweak the 'low OAT' end again when it gets colder.
- 2,775 Topics
- 65.4 K Posts
- 813 Online
- 7,180 Members
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 1 hour ago
This just might need a rebuttal (possibly marginally mo...
By cathodeRay , 3 hours ago
@downfield I just checked this morning and OE just r...
By Papahuhu , 3 hours ago
No, it isn’t just you Mars (I think you already knew th...
By Toodles , 6 hours ago
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 18 hours ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 1 day ago
@mrkfm, I’m definitely not trying to put anyone off get...
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 2 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 3 days ago
Posted by: @ian-s Could always use the money saved o...
By Rob of York , 3 days ago
Depends on what controls the pump! Thats the whole poi...
By Old_Scientist , 4 days ago
By JamesPa , 5 days ago
