Using Annual Gas Consumption to understand what an ASHP may consume in electricity
I have a 1920s 4 bed detached house in Surrey and I am thinking of changing to an ASHP. My gas bills show that I use 29,000 kwh per annum of gas - is there an easy way to understand what might be achievable in terms of electricity use from an air source heat pump to achieve the same level of heating? or are there too many other variables?
Hi Nick,
Its more important to understand the current setup of your property in regards to insulation, double/triple glazing, radiators/underfloor heating/pipework etc.
There are a couple of review/threads on the forum where people post their data but every property/installation is different so its hard to compare to your property.
What is pushing you towards looking at an ASHP?
Posted by: @nick-tI have a 1920s 4 bed detached house in Surrey and I am thinking of changing to an ASHP. My gas bills show that I use 29,000 kwh per annum of gas - is there an easy way to understand what might be achievable in terms of electricity use from an air source heat pump to achieve the same level of heating? or are there too many other variables?
If the system is designed and operated properly, you should cut about 20-30% off that.
@george . I want to dispense with my gas connection altogether in order to reduce carbon emissions. I understand that the Domestic RHI is ending in March 2022 and the replacement scheme would seem to be a reduction in the value of the incentive for a property my size (flat 5k vs about 10k spread over 7 years).
Hi Nick,
Welcome to the forum.
As a very rough, ballpark figure, you could probably expect electrical energy consumption to be 1/4 that of your gas consumption, if you were to fit a well designed, installed and optimised ASHP system.
If your objective is to save the planet and don't mind the additional cost, based on present gas and electricity tariffs, then you are to be commended. If your desire is to help save the planet and also improve your bank balance they it may be best to look at improving the level of insulation first.
Posted by: @jeffHave I miss understood
@heacol says 20% to 30% off the gas consumption figure?
@derek-m says 75% off the gas consumption figure?
Hi Jeff,
I think it may be a freudian slip. I do believe Brendon's statement should read ' 20% to 30% of the gas consumption figure', which of course would be approximately the same.
Dependent upon the heat loss of the property, along with the type and size of the heat emitters, a conservative estimate would be a SCOP of 4 for a well designed, installed and optimised system. Without specifics it is impossible to be any more accurate.
Thanks - this now makes sense and would bring the cost of electricity to roughly the same ballpark as gas.
I have a few questions on how best to optimise but I will start another thread on that.
As a rough comparison I had 3 quotes in Nov 2020 for:
14Kw Mitsubishi Ecodan pump
250l DHW tank
6 new radiators
MMSP
One came in at £14K and the others (which may have been £1K extra) were willing to match. They all charged £1K for MMSP which was included in the £14K.
Regarding MMSP. although it may sound like it's for geeks I would highly recommend having it installed, especially if you intend registering for RHI as you get it for free effectively.
I'm just going through fine tuning my ASHP on another forum topic and MMSP has been invaluable in identifying how the system is performing and whether action needs to be taken.
It will also allow the installers to remotely access your system if an error can be resolved without an engineer visit.
- 2,776 Topics
- 65.5 K Posts
- 2,339 Online
- 7,183 Members
So, if they are keeping within the rules to ev...
By ASHP-BOBBA , 9 seconds ago
Hi Mars,Just at the start of my Renewable journey and w...
By Paul1098 , 57 minutes ago
My fifth heat pump book, Heat Pumps Explained, is out n...
By Mars , 7 hours ago
Just furkled Into the parameter menu. Found the master ...
By AgentGeorge , 8 hours ago
It's interesting that Norway with a much colder climate...
By Rob of York , 8 hours ago
Happy to add Scottish Power and the review 'dont touch ...
By JamesPa , 13 hours ago
By tomasmcguinness , 3 days ago
@mrkfm, I'd also suggest that whenever you're ready, st...
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 3 days ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 3 days ago
