Posted by: @editorInstallers don’t like to enable weather compensation because it’s a trial and error system which leads to multiple call outs, so they just set the system to one flow temperature.
My advice is for you to experiment with the heat curves to get it running optimally for your house and your personal comfort levels.
This is why homely is such a great concept. It’s much more than a thermostat, it’s an automatic weather compensation optimiser. It’s a total game changer really.
@alec-morrow Just a basic system, standard Vaillant controller plus a SensoComfort panel. UFH throughout with a thermostat in each room.
Set all on off controls to maximum, and raise the heating curve to something more appropriate say 1.4, they come out if the factory at about 0.6
if the sensocomfort isn’t in a habitable space get it moved there
Professional installer
@alec-morrow I've got the heat curve set to 1.0, was thinking of working down from there rather than up. My thinking was to reduce the flow temps as much as possible whilst keeping the house warm - have I misunderstood how it works? SensoComfort (who thinks up these names??) is in the main area.
@hughf Is Homely relay switching..or does it speak multiple bus languages?
@squonk going up is as good as going down. make sure you have room control set to on, or extended...other wise it will just work around the outdoor temperature (which works very well) as it manages the "cycling" relative to the outdoor temperature and no indoor influence. (weather compensation has been mandated in Germany and other countries since 1985, so it is refined)
Im not sure why adaptive heat curve should be set to off.. I use it all the time and it works!
Posted by: @alec-morrow@hughf Is Homely relay switching..or does it speak multiple bus languages?
Modbus over 485 - at the moment it's only coded up to support Midea and Samsung (because a certain Mr GH consults for them) but their developers were keen to code up support for the Carel controller that's inside the Cool Energy units. They offered me the option to be their beta tester for this integration.
It will also commission the units (again, over modbus) so there's no need to go into the controller and manually change all those parameters. It will also make a decision on whether to run load comp or weather comp depending on the spot rate for electricity and the demand for heat (geofencing etc). It's a very cool idea - my only complaint is that there's no in-home display or interface, just the app to control the setbacks/schedules for DHW etc.
Posted by: @alec-morrow@squonk going up is as good as going down. make sure you have room control set to on, or extended...other wise it will just work around the outdoor temperature (which works very well) as it manages the "cycling" relative to the outdoor temperature and no indoor influence. (weather compensation has been mandated in Germany and other countries since 1985, so it is refined)
This is the Vaillant recommended config:
System
Adaptive heat. curve - No
Configure heat. circ. - Zone1
Hybrid manager - Bivalence point
Heat. bivalence point - 20°
DHW bivalence point - 20°
Energy supplier - Heat off
Auxiliary heater for - Inactive
System diagram configuration
System diagram 10
Additional module
Multi-function.output2 - Circ pump
Aux. heater output - Off
HEATING
Type of circuit - Heating
Max limit outs.temp. - 30°
Heating curve - **Site specific
Minimum temperature - 15°
Maximum temperature - 45°
Auto Off mode - Eco
Room temp. mod. - None
I agree it seems odd not to use Adaptive Heat Curve (assuming it does what it says on the tin) or Room Temp Mod.
Just keep teasing the curve up... you can also just raise the target room temperature, that lifts the curve. With "none" selected in room control it is a calculated room temperature or virtual room temperature. Heating is a science so outcomes are predictable. actual settings ie running it at 24c and room temp being 22c is fine if you are comfortable..fine tuning can be fun though!
Posted by: @alec-morrowJust keep teasing the curve up... you can also just raise the target room temperature, that lifts the curve. With "none" selected in room control it is a calculated room temperature or virtual room temperature. Heating is a science so outcomes are predictable. actual settings ie running it at 24c and room temp being 22c is fine if you are comfortable..fine tuning can be fun though!
Do you think we will ever see the process automated as standard?
It often appears the sector hasn't moved forward for decades vs other industries?
I can't think of another consumer offering so manual?
Why aren't we seeing more progress in manufacturers controls?
- 2,114 Topics
- 46.4 K Posts
- 20 Online
- 3,410 Members
By Mars , 12 hours ago
By Toodles , 1 day ago
By Brendon Uys , 1 day ago
By Burtis , 2 days ago
By trebor12345 , 2 days ago
By Lucia , 3 days ago
By Ashfp , 3 days ago
By Mars , 5 days ago
By Mars , 7 days ago
By Prunus , 1 week ago
By Mars , 1 week ago
