Samsung Gen 6 - Schedules not working
Glad you got it sorted 😀
@bontwoody you are welcome and that is good news it is sorted.
Posted by: @bontwoodyI must have set holiday modes when I was trying different ways of turning it off for the summer
I would recommend looking into setting up yearly schedules to solve this problem.
For example I do not have weekly schedules set up but instead have a "Summer" schedule set which is active May to September. Under the summer schedule the space heating is set to switch "off" at 3am Monday to Sunday so the heat pump does not run over the summer.
I have an Autumn schedule which is active October and November under which the heat pump heats the house to 20 degrees in the day and heats the house to 18 degrees at night.
Then November to March the "Winter" schedule becomes active and heats the house to 21 degrees in the day and 19 degrees at night. The Spring schedule is active in April and is the same as the Autumn schedule regarding temperature profile.
This method allows you to set up and forget 😀
Regards
Bivalent system containing:
4.1Kw Solar Panel Array
@technogeek That sounds very logical :-). I will give it a go. Thanks for your help!
- 212 Online
By JamesPa , 18 minutes ago
By Batpred , 48 minutes ago
By Sheriff Fatman , 54 minutes ago
By Batpred , 1 hour ago
By IRMartini , 2 hours ago
By GC61 , 2 hours ago
By cathodeRay , 5 hours ago
By cathodeRay , 6 hours ago
By JamesPa , 17 hours ago
By Batpred , 19 hours ago
By cathodeRay , 19 hours ago
By DavidB , 22 hours ago
By Batpred , 22 hours ago
By JamesPa , 24 hours ago
