Red Expansion Tank
@bobtskutter Hi Bob. Daft mistake with the valve.
The red expansion tank is not attached to the hot water cylinder.
I can't find the PSV you mention on the heating side.
Filling the system from 0 to 1.5 did not take long although I did slow it down towards the end. I'm only guessing maybe 5 seconds and then a few more.
The installer did ask me to check the auto air valve on top of the buffer tank to see if wet. Totally dry and always auto open so I don't know if it's been venting air. Maybe that's it!
A few weeks ago the system was drained down so maybe trapped air in the system has suddenly found it's way out. Hope that's the reason and why the pressure only dropped.
Will monitor the pressure over the weekend.
Install 13 April 2024 - 4 Bedroom Brick Detached - Heat Loss 9,281w, Design 45c at -2 - Ecodan 11.2kw R32 - 25L Buffer - 250L Telford Tempest HP DHW - All 16 radiators replaced - Auto Adapt - Mel-Pump app - Octopus Fixed Rate
@bobtskutter Hi Bob. Just a short update to say that the Red expansion tank guage is stable on 1.2 reinforcing my thought that it was air in system. It was drained down 4 weeks ago and maybe the release of trapped air was delayed or maybe I just hadn't noticed it.
I will still keep an eye on it though.
- 2,114 Topics
- 46.4 K Posts
- 70 Online
- 3,410 Members
@toodles I never used smart+ with ours, so no reason re...
By benson , 25 minutes ago
By Mars , 5 hours ago
By Toodles , 20 hours ago
By Brendon Uys , 1 day ago
By Burtis , 2 days ago
By trebor12345 , 2 days ago
By Lucia , 3 days ago
By Ashfp , 3 days ago
By Mars , 5 days ago
By Mars , 7 days ago
By Prunus , 7 days ago
By Mars , 1 week ago
