My ASHP is not performing as well as I’d hoped: COP just over 2
@hcas - exactly so. I did read one other persons similar experience but the overshoot was lower if I recall correctly. I can only make this comparison because I have an electric meter just on the cable for the heat pump, but as it is not close the FTC unit I cannot connect an output from it to the FTC which would then replace the unit's own guesstimate with the metered value. This is what most people who have invested in metering will have done.
210l Mitsubishi solar tank
Solar thermal
3.94kW of PV
Have been incommunicado for a while. Now back online and will revisit this thread asap.
@toodles No. But I wasn't forced there either and The King had nothing to do with my trip LOL.
Just when I returned I had no internet which has now been resolved.
- 31 Online
By Scalextrix , 34 minutes ago
By HCas , 2 hours ago
By HCas , 3 hours ago
By GrahamF , 6 hours ago
By immunity , 8 hours ago
By JamesPa , 13 hours ago
Just done your survey!
By Judith , 23 hours ago
By Judith , 24 hours ago
By Tasos , 1 day ago
By Scalextrix , 2 days ago
By bontwoody , 3 days ago
By Alex , 3 days ago
By GrahamF , 3 days ago
By DREI , 3 days ago
By Profzarkov , 3 days ago
