Lambda Eureka Air heat pumps
I just came across this German ASHP: https://lambda-wp.at/luft-waermepumpen/ (Use your browser to translate to English.)
Does anyone know why it is not available here (at least I can't find it for sale)? I can see that even the 8kW model is too big to qualify for permitted development under current MCS rules, so that would limit the market. But plenty people end up having to apply for planning, so there should still be a market for it in the UK, especially in view of it having sound power of 42dB, which would really help those who are struggling to get planning permission on noise grounds. (Or am I misunderstanding the sound power figures?)
As I understand it, the size limit for permitted development might be increased, because ASHPs could perform much better if they were allowed to be bigger. Is the Lambda an example of the benefits of allowing a bigger machine?
The other big advantage it seems to have is its SCOP. According to Crog ( https://crog.uk/heatpump/2024/02/15/5Kw-Heat-Pump-SCOP.html ), it is significantly better than Ecodan, Vaillant, Samsung.
The same comments seem to apply to the Ovum Aircube. https://www.ovum.at/en/produkte/luft-aircube-outdoor/
I wish our uk ASHP's could be made more attractive like this. Ours are so tedious and ugly (in my humble opinion).
Daikin 6Kw ASHP.
The maximum Lambda sound power seems to be 56dB, judging by the tech specs:
Which is better than, say, Daikin, but not better than some on the UK market.
@ivanopinion have you checked the MCS database – most European heat pumps will get MCS accreditation, so if they're on the database, they'll be available in the UK. I'll also ask some people who might know.
Free UK shipping.
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
@ivanopinion I’ve searched the database and this unit isn’t listed, which means it’s probably not available in the UK.
Free UK shipping.
🛠️ Bodge Buster
New to heat pumps?
- 2,775 Topics
- 65.4 K Posts
- 1,342 Online
- 7,180 Members
@mrkfm, I'd also suggest that whenever you're ready, st...
By Mars , 7 hours ago
I'd rather be like this, than answering all th...
By Singlespeed , 8 hours ago
RE: Are you planning to use a wood burner to supplement your central heating this winter?
I use my stove daily for backup and comfort. Definitely...
By Margarethomas , 12 hours ago
@rob-of-york Thanks. I wish I'd started on this site as...
By mrkfm , 14 hours ago
This just might need a rebuttal (possibly marginally mo...
By cathodeRay , 16 hours ago
@downfield I just checked this morning and OE just r...
By Papahuhu , 16 hours ago
Thanks Will. I'll probably be a week or so before get...
By Singlespeed , 1 day ago
From experience this summer, a single-split A2A unit on...
By Rob of York , 2 days ago
Analysis of the economics of switching to an A2W ASHP compared to other heat sources
This post aims to analyse the economics of installing, ...
By Rob of York , 3 days ago
@editor does that mean you have to have two separate ex...
By mrkfm , 3 days ago
Posted by: @ian-s Could always use the money saved o...
Depends on what controls the pump! Thats the whole poi...
By Old_Scientist , 4 days ago
