Hydronic plinth heaters and ASHPs
Hi all,
Wondering if anyone had experience of the above, combined with ASHPs?
Redoing our kitchen at the moment. UFH is a no go. Looking at the plinth heaters some of the larger ones will just about meet the heat loss of my kitchen (pretty much dead on in fact), and will involve significantly less plumbing work than what I was looking at doing with having to move/change the radiator to accommodate the plans with the units.
Thanks
We have one and it’s a bit undersized since it was the original on the hotter water gas system. But nevertheless we only needed to flick it on for a few hours this last winter.
The only subtlety is it has to be on the summer setting (Myson 1kW) since on the winter setting the fan switches off when the flow temperature is below a (can’t remember) value.
It works very well because being fan driven the wattage reduction with flow temperature is not as steep as a radiator.
@judith thanks. Good to know yours is working well. There do appear to be some that cater for lower flow temps, as in fan won't switch off on certain models, which is good. The only thing I can't quite get my head around is how they would be balanced as a normal radiator would, with lockshields, and whether this would lead to inefficiencies. I could get a radiator into the revised plans it would involve taking a fair few floorboards up, and I think extending the tees to the radiator around 3 metres as well to get it over the other side of the room.
Posted by: @bensonThe only thing I can't quite get my head around is how they would be balanced as a normal radiator would, with lockshields, and whether this would lead to inefficiencies
I have a mitsubishi wall mounted fancoil which is I think essentially the same construction as a plinth heater. No hydronic balancing needed, it modulates the fan speed to adjust the temperature. Great piece of kit except that it turns off when the water temp goes below 30C and this figure is not adjustable, which could cause problems at the ends of the season. For me it's just about ok but I can see it may be problematic in some cases.
- 22 Forums
- 2,048 Topics
- 44.7 K Posts
- 28 Online
- 3,276 Members
RE: Hydronic plinth heaters and ASHPs
I have a mitsubishi wall mounted fancoil which is I thi...
By JamesPa , 5 hours ago
Historically, it's been low generation from fossil fuel...
By Transparent , 11 hours ago
RE: Additional Battery v Wind Turbine v Ripple
There was a call today for Ripple investors and amongst...
By Judith , 14 hours ago
RE: Yes, the "zoning with ASHP" topic again...
Thanks, James — that’s a really encouraging and fair re...
By HarryRea , 15 hours ago
@heatgeek I kind of get it… but aren’t you still in the...
By SUNandAIR , 16 hours ago
I think you may very well be right and of course A2A ca...
RE: Agile: average import cost vs other tariffs?
@old_scientist We are with SSEN and our G99 application...
Yes. Storing the solar generation within the home is gr...
RE: ASHP Ecodan L9 error - No Heating but Hot Water
@phoenix15, @heacol cover your area… I’d strongly recom...
RE: Warm weather and heat pumps.
@editor Oh nothing right now because $ needed for struc...
By Lucia , 3 days ago
RE: Potentially more choice including air to air heat pump grants
@jeff Such documents are far too wordy for my ‘daily re...
By Toodles , 4 days ago
@grahaml I cannot agree that it is a small percentage o...
By benson , 4 days ago
RE: Samsung Gen6 16kW tribulations
@emceed, can you please give us an update on your syste...
By Mars , 5 days ago
What's the problem you are trying to solve. The answer...
Good luck. For what it is worth my system was very def...
RE: Massive Electricity Cost for Running My Air Source Heat Pump
I agree @mark-h The Building Regs are now very readable...
By Transparent , 1 week ago
RE: Help me understand my Mitsubishi Ecodan system
@carpenterstation When changing settings in the ser...
By RobS , 1 week ago
