Hybrid oil and ashp experiences please
@editor Thanks Mars. Wow, that’s expensive. Surely it would be cheaper to run the ASHP at a slightly higher temperature?
@julianc, it's very pricey – we're in the process of doing the maths and trying to see how things stack up in terms of costs and CO2 emissions.
Posted by: @editor@julianc, it's very pricey – we're in the process of doing the maths and trying to see how things stack up in terms of costs and CO2 emissions.
Do you think at some stage will have to improve the insulation/draft proofing and invest some money in your ashp setup where you already know there are issues?
Can't be an easy decision working out where to invest but i assume it should be possible to run your ashp alone more efficiently with further investment? I do feel for your situation.
- 2,112 Topics
- 46.4 K Posts
- 30 Online
- 3,405 Members
By benson , 13 hours ago
By marcinwloch69@gmail.com , 16 hours ago
By JamesPa , 20 hours ago
By Transparent , 1 day ago
By Wh0am3ye , 2 days ago
By TechnoGeek , 4 days ago
By JamesPa , 5 days ago
By seatonian , 6 days ago
By Toodles , 6 days ago
By ASHP-BOBBA , 6 days ago
By EcoBaker , 7 days ago
By Bart , 7 days ago
