High air source hea...
24 Users
127 Reactions
65 K Views
(@aceshigh)
Posted by: @webcmg
@aceshigh @colin I isolated the secondary return at the weekend and today the DHW has not had to recharge following yesterday's anti legionnela cycle. The temperature has remained above 50 degrees even though we've both had showers. It does take marginally longer to get hot water, but I prefer this if we're saving energy. So this is a positive sign. I wonder if this issue has impacted the ASHP performance for the heating. We had our DHW on constant and can imagine it would need to keep cutting in to recharge the DHW. When it did this perhaps the flow temp for heating dropped, incurring greater consumption to get back to desired temperature. Something to monitor but positive signs. I just wanted to say many thanks to you both for taking the time to help me. It is greatly appreciated. Thank you.
@aceshigh Do you know if it is possible to plumb in a secondary return so it does not syphon? It might be nice to circulate on demand at particular times of day (which is what the pump with attached timer is supposed to do, but it didn't ever need the pump. A motorised control zone perhaps?
@colin it sounds like we have similar setups and houses (minus 2 children). What is your current daily electricity kwh usage for the house? I'm looking for a comparison because ours is still 6 kwh without any ASHP usage. I don't think we have several tvs on standby, two fridge freezers and a lot of Philips hue devices on standby. Not sure if 6 kwh is good or bad...
Sorry for the delay, notifications for this forum go to my spam folder.
The installer I used suggested fitting a motorised valve, linked to the same timer that operated the DHW return pump, he did warn that while it would solve the Syphon problem it would likely cause the pump to fail prematurely or cause noise as the pump would be running immediately while the valve was still opening.
I looked at this and if I went ahead with a valve I would actually make use of the control wire (just like if it was being used by central heating) such that the timer operated the valve, then the valve operated the pump once it had opened.
However like others have suggested earlier, a London loop can be used, I have attempted to get more information on this but my Google-fu is failing me; I need to figure out whether a downward loop is required on only the outlet or return of the DHW pipes or both.
Thanks
(@webcmg)
@aceshigh I wonder if a control valve and no pump would work? Surely it would simply syphon when the valve opened?
 robl
(@robl)
@Aceshigh
The thermosypon effect will be from any hot water store, where a pipe exits and heads upwards, or horiz then upwards.  It's most likely just the top of the store that's the issue, as the return pipe at the bottom is generally cold preventing the effect.  So I would expect the issue arises if you have a hot tank, with the flow pipe at the top of the store going upwards or up + horizontal - then inside the "up" sections there will be circulating water flows, efficiently stealing the heat from below and moving it upwards.  The water isn't flowing all the way around the whole circuit, it's just local convection in that section of pipe.
So - check the pipes from the store - the ones that are hot long after they should have cooled, they're the ones which are thermosyphoning.  It's likely to just be the DHW out pipe, but it could be more of them, no reason why not.  These ones could do with this "london loop", which I think is an added (minimum)10cm down + 180 bend + 10cm up section of bent pipe.
Linky has pic of solution:
https://www.diynot.com/diy/threads/preventing-thermosyphon.539906/
(@aceshigh)
@robl thank you. It's definitely the complete circuit (DHW out and around to the DHW return) - exasperated by the Mixergy technology with their pump on the tank to take hot water from the top and blend it with cold water at the bottom to get the tank hot throughout.
If I close the DHW return pump valve the siphoning stops and the tank stays very hot for a couple of days.
I'll look to add the downward loop to both the DHW out and return and hopefully that cures things.
(@webcmg)
@colin do you know if you can set the legionella cycle to trigger at the same time as the scheduled water charge period?
(@colin)
@webcmg Yes, I do this with already, I have everything to start when the daily electricity tariff is 5.5p.  On the flip side, if you have it set at different times for example you had the the legionella cycle set to 7pm and it finishes at 9pm, and your daily heat schedule is set to 10pm, then the 10pm cycle will just skip because the temperature threshold is already met.
(@webcmg)
Posted by: @colin
@webcmg Hi, I'm using a free bit of software called 'Home Assistant' that can run on almost anything including old PCs. link: www.home-assistant.io/
I'm using the below Home Assistant Vaillant integration to monitor the all the Vaillant kit, Pump/Cylinder/Controls.
Link: github.com/thomasgermain/vaillant-component
It's helped me a lot by getting a bit more understanding about what was happening under the hood and optimising our consumption but I appreciate it needs a wee bit of technical know how.
Finally got a HA install setup. Struggling to add the custom repositories, what url/address did you use?
(@colin)
@webcmg Hi, instructions are in the link at the bottom.
First you install HACS, then add the Vaillant Component repository. When adding the device, give it the internal IP address and username/password. It also prompts for the serial number but I don't think it matters.
Note: It says it doesn't work with Sensoapp however that's the smartphone App I use and it's fine for reading temperatures & electricity usage.
https://github.com/thomasgermain/vaillant-component
(@webcmg)
Posted by: @colin
Thanks, but I've not been able to add it as a repository from github yet. I tried the github url but states its not a valid repository. If I try a deeper url it just returns errors...
(@colin)
@webcmg Did you manage to install HACS?
Once you're into HACS, click the top right with three dots to add the custom repository.
Screenshot 2022 07 24 at 22.35.51
(@webcmg)
Posted by: @colin
@colin getting there slowly... installed HACS. Installed the custom repository, but really can't see where I can add a device.  Appreciate you're not technical support, but any futher advice would be most welcome! Thanks.
(@webcmg)
Posted by: @webcmg
Posted by: @colin
@colin just found it in integrations. It is a steep learning curve!
Page 13 / 20
