Help for newbie Sam...
Help for newbie Samsung ASHP owner
3 Users
4 Reactions
(@cathyem1)
Hi Everyone,
a friend has a new Samsung ASHP and her hot water isn’t working.
I have a Baxi so I don’t know anything about Samsung.
Does anyone have any gems of advice for her please?
Many
cf54c1e1 ca0c 4082 a1a5 249d2ec7abfa
thanks
Cathy
Has she programmed a schedule for the hot water on the controller?
The manual to look at is the controller manual not the manual for the Outdoor unit that you show in the photo.
Thats also the place to look to see what is (or at least should be) going on.
(@cathyem1)
@jamespa I’m not sure I’ll ask. Thank you
(@cathyem1)
@jamespa thank you
Installer should have done this really but who knows.  Programming a dhw time schedule will be pretty straightforward, suggest 90 mins once or twice per day with target temperature of 48.
(@cathyem1)
@jamespa No time set - I’ll let her know that. Thank you
(@cathyem1)
Is it easy to set the timer?
Posted by: @cathyem1
I dont know as I dont have a Samsung.
I looked quickly through the manual and its there, but TBH it didn't seem as straightforward as one might hope.  That said its difficult to judge unless you actually have one in front of you.  Doubtless it becomes more obvious if you do have one in front of you.
Installer should definitely have explained how to set the DHW timer as its the sort of thing you need to do!
(@lenny)
@cathyem1 Yes.
How to set up the hot water time clocks on a Samsung heat pump HTQ, R290 and Gen 6
Samsung 12kw ASHP, nine 415w PV panel array, upgraded radiators and DHW water tank (+ pumps etc). Two wireless zone thermostat controllers and Samsung MWR-WW10N
