Heat Pump Sizing & ...
Heat Pump Sizing & Installation Costs
7 Users
5 Reactions
Topic starter   [#2186]
I’m doing some research for an upcoming article and podcast, and I’d love to gather some data from our homeowners on the forums that have installed heat pumps. If you’re willing to share, it would be massively helpful!
What I’m looking for:
• Property size (in square metres)
• Heat pump size (in kW – e.g. 5, 6, 12kW, etc.)
• Approximate installation cost (heat pump, labour, etc.)
If you’re happy to share your figures publicly, please post them in this thread. If you’d rather keep the cost private, feel free to DM me or email me at @renewableheatinghub.co.uk" target="_blank" rel="noopener">editor@renewableheatinghub.co.uk
Info sent to me in private will be kept confidential and will only be used for statistical purposes.
Thanks in advance to anyone who contributes.
Free UK shipping.
📗 Heat Pumps Explained
📘 From Zero to Heat Pump Hero
🛠️ Bodge Buster
New to heat pumps?
(@tim441)
Honorable Member Contributor
Perhaps useful to have installed date too? To get context...my example:
LG Therma V 16kw monobloc
Installed Aug 2020 replacing oil
Approx £12k. Included replacement hot water tank and one radiator. RHI grant
200 sq m (100 sq m listed building, poor insulation. + 100 sq m modern extension with excellent insulation). Underfloor heating downstairs throughout.
LG Therma V 16kw ASHP
Underfloor heating + Rads
8.7kw pv solar
3 x 8.2kw GivEnergy batteries
Manual changeover EPS
MG4 EV
(@adrian)
100m2
5kw
£11000-£7500=£3500 pick 3 radiators
2024
200sqm
7kW
200l UVC
2 new rads, one new fancoil, one existing rad relocated (total 4 rads changed)
16A feed for heat pump already in place so not included
£12,450 less grant = £4,950 net
Work duration - 6 man days of approx 9 hours each
Abernyte
(@abernyte)
2019
180sqm timber frame
14kW
300l DHW
16 new rads K2 and K3, new delivery pipework, new electrical consumer unit
£12,200 less RHI (Scot) £13,200 over 7 years
6/7 days for 2 heating engineers and 1 sparky
(@johnr)
1970s 4-bed detached house approx 168 sq.m internal area in central southern England. Approx 200mm of roof insulation, insulated cavity walls, fairly recent double glazing including a 3m wide two storey north facing widow which is triple glazed but a heat loss due to its size (big curtain closed in autumn and opened in spring).
£16,600 for 7kW Vaillant Arotherm+ heat pump including SENSOcomfort controls, SENSOnet gateway, Telford Tempest 250 litre combined DHW cylinder / buffer tank and 11 new radiators.
Installation took about 20 person-days of work. There was significant pipework modification to accommodate larger radiators and one new radiator and probably above average work to connect the heat pump as it was two rooms away from the cylinder (placed in what I considered to be the most convenient location).
I suspect I paid a generous price but it was the only convenient quote from an installer who appeared to understand the technology and I wanted the work done during the summer (Octopus offered a lower price but with a likely installation well into the autumn and would only change such radiators as they deemed necessary). Radiator replacement was steered by both the heat loss calculation which I compared with my own estimate, my knowledge of where more heating was needed and my desire to replace all radiators which weren't 21st century. The work was done competently and fitted in with my own needs such as radiators were removed and I was given a few days to do decorating before new ones were fitted.
The 7kW sizing seems to be correct. The maximum hourly output so far according to the Vaillant app was 7.6kW for 7 to 8am on 11th January when the outside temperature was -7C and the heating had been turned up after a modest overnight setback. However, I suspect that Vaillant are over-estimating the output as a daily COP of 3.9 for that day (mean temp of -3.7C) is almost implausible. Nonetheless, generous radiator capacity keeps the flow temperature below 40C under the worst conditions.
More details of the work are attached.
(@majordennisbloodnok)
Ours is a 1930s bungalow with extension and loft conversion and is now about 105 sq m. Generally well insulated but we did replace french doors, front door and two small kitchen windows that were all found to be losing more heat than they ought.
We replaced our oil boiler with an 8.5kWh Mitsubishi Ecodan in December 2021. No radiator changes were needed but there was a reasonable amount of pipework needed replacing with wide bore pipework and a new hot water tank was installed as well. They also had to install a separate sub board specifically for the heat pump to avoid tripping the switch on startup (which it initially did intermittently). In total it cost £15k inclusive of the vodka and tonic, but given the RHI it came to a net cost to us of about £4k. The guys spent about 5 days on site including the troubleshooting that eventually led to the installation of the sub board.
The subsequent three years or so have shown a number of areas which are frequent forum bugbears that our guys did right unbeknownst to us (newbies that we were back then). No red flags were raised then nor any since and our bills have dropped markedly as a result.
I should also say we then opted for their 5 year maintenance plan for another £950 hence a squidge under £200 per year which has subsequently been shown to be reasonably good value, particularly since each time they've turned up to do the servicing I've seen them actually working for their money rather than just tinkering. Is it money for old rope? Probably. Is it a rip-off? At that price and given the attention they show, no. Are we satisfied? Absolutely.
