Ecodan software update. Real or scam?
Posted by: @morganJust received an email telling me that my Ecodan ASHP requires a software update. Anybody else had this and confirm it isn't a scam of some sort please?
email is from: meu-uk.lesecodanquality@meuk
Hi - last week a Mitsubishi service tech installed a software update to our 11.2kW R32 unit. Apparently it alters the behaviour of the linear expansion valves (located above the accumulator), as a precaution to avoid a potential problem with noise due to oscillation of the valves. We don't have any experience of any such noise problems.
Guessing it could be the same update as the one that I just spotted you had mentioned here.
Mitsubishi were supposed to come on two previous occasions but cancelled at the last minute.
- 22 Forums
- 2,086 Topics
- 46 K Posts
- 20 Online
- 3,377 Members
By benson , 46 minutes ago
@tomasmcguinness bold choice on the Kronoterm. Nice! Wi...
By Mars , 6 hours ago
@jamespa I have a hydronic baseboard heater in the kitc...
By Scalextrix , 2 days ago
By Bart , 2 days ago
Here’s a little more technical detail/p>
By Judith , 3 days ago
By AF1 , 4 days ago
By Old_Scientist , 5 days ago
RE: Plate heat exchanger considerations
As far as I can tell my vented system would have a peak...
By Scalextrix , 6 days ago
RE: Air Changes per Hour - ACH and the MCS requirement
There have been a few discussions dotted around (e.g. I...
By Declan90 , 6 days ago
