Mitsubishi Ecodan F...
Mitsubishi Ecodan F8 error
6 Users
4 Reactions
Posted by: @ashp-bobba
Just to add to the F8 non existing code, in the book is all of the blinking codes and could be worth double checking it not trying to display a P8 which could look like a F8
I absolutely love this. This is the quintessential heat pump user experience.
Mitsi spent millions on the vapour compression cycle, only to delegate diagnostics to a single LED trying to communicate the difference between a Fault () and Performance issue () via blinking cadence that may or may not exist. I love it. It's less an error code and more a Rorschach test. 🤯
Better than an early Windows/DOS error 'Faulty keyboard or keyboard not present, press F1 to continue'.  This persisted for a couple of decades at least.
There may actually be some sense in the flashing led thing, it probably works even if the circuit that is responsible for the display isn't working thus proviving a fall back basic diagnostic.  Computers emit a series of beeps on startup, the pattern of which depends on faults, for this precise reason.
This post was modified 4 months ago by Mars
Page 2 / 2
