This particular example is one of the worst I have seen here. Uninsulated buried primaries!, uninsulated pipework around the cylinder, system separation, oversized heat pump, undersized radiators and doubtless some things we don't know about because they are masked.
The plumber who 'installed' this should be struck off! It's almost like they designed it not to work, but I doubt they were that competent. The lack of insulation would be equally bad if this were a boiler installation (worse in the case if the dhw tank, because it would be heated to a higher temperature), how were they ever let near this job. It makes one wonder about the rest of the plumbing.
Mitsubishi Ecodan 11kw Defrosting Issue.
6 days ago
Have Consumers Been Lied to About the Efficiency of Heat Pumps Made in China?
1 month ago
5 months ago
5 months ago
Ecodan 11.2kw Wireless thermostat drop outs
5 months ago
- 51 Online
I doubt it, many 'improvements' are quite the opposite....
By cathodeRay , 45 minutes ago
@julianc Expressed as a flow diagram, I suspect one wou...
By Toodles , 1 hour ago
@jamespa The dormitories at my boarding school (in Exet...
In the last week, the external temperature in south Man...
By GrahamF , 17 hours ago
By JamesPa , 17 hours ago
By JamesPa , 18 hours ago
By Scalextrix , 20 hours ago
By Paul G , 21 hours ago
@pash44pump Referring to the problem of rooms with diff...
By Tasos , 22 hours ago
By JamesPa , 23 hours ago
@damon thanks. I will do as you suggest. Hopefully I wi...
By bontwoody , 2 days ago
By pash44pump , 3 days ago
By Cleardene-ashp , 4 days ago
By JulianC , 4 days ago
By Old_Scientist , 4 days ago
By ASHP-BOBBA , 5 days ago
