Check the thermistor readings as detailed in the attached video.
If the controller is indicating -39C then check to see if the controller is correctly configured. Also check to see if the thermistor is wired to the correct connection.
@ngillam now you have access to the app at the bottom of the screen is a reports tab then press hourly temperature it will display the flow and return temps for the most recent hour. At the top of the screen will be the time press that and you can select any hour in the last 24 hours so you can see exactly when the heat pump was on and what temp it was running at.
As your system is running off 3rd party thermostats that -39C reading won’t matter it’s the temperature near to the controller unit.
Hello Gary,
Still struggling with this, seems we can't get the house cool enough, won't go below 22degs, if I alter the WC curve to its lowest temp (20degs) then I suffer cycling which I've seen on other threads. It seems the house is really well insulated and we're just not losing the heat, the other half is getting a bit annoyed at the high temps.
Any suggestions?
Thanks,
Neil
At this time of year you will need to use your thermostats to limit overheating. Are they heatmiser as well? Now you have set the warm end of the curve you can set the thermostats to the max temp you want then the heat pump should shut off unless you have multiple zones in the UFH linked to numerous thermostats?
@gary This is my set up, I thought the idea was to let the heatmisers (in each room) run free? Mine are at 35 degs but sit at about 22 degs. my partner wants to open windows to cool the place off but that seems wasteful. All underfloor heating is hard to control.
If you can’t control the house temp through the flow temps you will have to have thermostats to stop the house getting hotter than required.
@gary By flow temps you mean those set via WC curve? Just had a thought, all the trickle vents are closed on the windows!!
I think you said your set up was similar to mine Gary, can I ask your KWH for Oct? heating and DH combined?
Thanks,
Neil.
Yes the flow temps in the WC curve you are running as cool as possible but that is still overheating the house so all you can do is turn it off when the house gets hot enough.
I don’t measure the heat pump consumption separately but I estimate it about 10kwh a day for water and heating in October. This is all done overnight at cheap rate the house doesn’t cool down enough during the day for the heating to come back on again.
Posted by: @ngillamall the trickle vents are closed on the windows!!
Not the best option for ventilation! You will end up with a house that hot and stuffy, the stuffy feeling isn't because it's hot, its rubbish air quality, humidity and high CO2 levels
- 2,153 Topics
- 47.3 K Posts
- 19 Online
- 5,673 Members
By ASHP-BOBBA , 5 hours ago
@pash44pump what we did to resolve a not too dissimilar...
By benson , 6 hours ago
My Samsung Gen6 (probably same controller as yours) onl...
By Old_Scientist , 14 hours ago
By JamesPa , 15 hours ago
By Old_Scientist , 17 hours ago
@rob-nezard you can see more of Drei's rad dramas here ...
By Mars , 17 hours ago
@drei I will say again that Im sorry to heat about your...
By JamesPa , 18 hours ago
By DREI , 1 day ago
1040kw Even beat June and July. Great month.
By Andris , 1 day ago
Hope they know what they're doing regarding paint types...
By PatrickVito , 1 day ago
By Toodles , 1 day ago
@bontwoody Maybe one for @editor to consider whether a ...
By ChandyKris , 2 days ago
@mars That response surely deserves a nomination for Tu...
Specifying batteries, pv solar etc using ChatGPT
I thought I'd try to use ChatGPT to specify my requirem...
By Tim441 , 2 days ago
When I interviewed Mitsubishi Electric at Installer ear...
@lucia One look at that protection and the rodents will...
