DHW SET UP with Samsung gen 5
Space heating is controlled by Danfoss thermostat and hasn’t been on as set to 20c and not needed . Here are my results , on the 10 Fsv’s only one needs noting as the rest is to do with room heating /cooling. So 10:51 is DHW Tank heating set at 54c 10:52 40c max/min
The 30 values written on the attached
Next is the timer for Daily . The first two slots are on off as you will see.
The last picture shows when timer settings goes back to Home Screen when Esc is activated .
I hope this helps Also attached is this note at the end of Daily settings in the Manual. FSV VALUE?
OK Im a bit stumped, but the good news is that someone in another thread has got it working (it may be a different generation but at least it gives a point of comparison), I have asked them to comment and you might wish to PM them.
I think the cryptic note you posted refers to 3031. This is a bit strange and suggests somehow they have economised on output or internal registers and combined two functions in a confusing way.
Can you check FSV 5041 which should be set to 0, and also 4011 and 4012.
Perhaps set the on time (initially) to something where you can monitor the operation (eg 5 mins after whatever the time is when you set it) and watch what happens and also check the actual water temperature at the time, temporarily modifying 3023 (or the target DHW temp set on the user display) if necessary so it should definitely trigger.
So I have done a short set up and it worked!I could get any lower difference than 5c so hiked up to 55c and set the timer , it seems to work now .
My main trouble seems to be that the controller is not saving my set times , when I go over the slots they have changed in some and not others.
I will go over them again this evening , but its so annoying! Thanks for your help ....again.
Posted by: @alfapatSo I have done a short set up and it worked!I could get any lower difference than 5c so hiked up to 55c and set the timer , it seems to work now .
Thats good news indeed, you are very likely almost there!
- 2,118 Topics
- 46.6 K Posts
- 120 Online
- 4,523 Members
@jamespa i just want it right at the end of the day, th...
By AdamK , 3 hours ago
By downfield , 8 hours ago
By Toodles , 8 hours ago
FRV valves - can you mix and match
Great video again this week @editor, I am very interest...
By Grantmethestrength , 9 hours ago
By normpang , 2 days ago
By ASHP-BOBBA , 2 days ago
By Burtis , 6 days ago
By Old_Scientist , 7 days ago
By Lucia , 1 week ago
