Daikin COP / energy used measurement from MMI
@crasher sorry, I missed your message.
I haven’t found a fix for this. I mentioned it to Octopus and a Daikin engineer when they visited and they were not very interested, stating that it was only approximate anyway.
So I setup ESPAltherma and have had it running for 3 months with Home Assistant:
https://raomin.github.io/ESPAltherma/
It is excellent and provides great insight into what your Daikin is doing.
@hcas I’ve got the Daikin integration for Home Assistant; it seems to show the same (bad) electricity data as the MMI 😔
@squarepeg77 Thanks for the reply. I never got an answer either but it just resolved itself, checked it a few days after posting here and all was good again I had readings back! I don't believe it to be 100% accurate but it gives a guide to how the unit performs. I've found the same with Daikin, they never seem overly interested in providing any help
@squarepeg77 Hi! Is it your ESPAltherma that is connected to Home Assistant? Or are you using the Onecta API for the Home Assistant?
And the ESPAltherma gives you the same wrong readings as the Onecta app and MMI?
Have you set up any home automation or smart steering of your heat pump?
Both ESPAltherma and Daikin integration connect to Home Assistant.
The Daikin integration exposes sensors that match the ONECTA app or MMI; so for me that means incorrect electricity consumption.
ESPaltherma is much lower level, but the electricity (voltage and current) sensors are considered inaccurate, so people seem to be using external monitoring. I’ve got a CT clamp around the heat pump feed that goes back to an Eddi, then I collect the data in HA.
If you want to get going with ESPAltherma, there’s an excellent guide here:
And yes, I am running a software thermostat in Home Assistant as the Madoka is too “quirky” for my liking.
Warm weather and heat pumps.
2 months ago
Oversized Daikin 9kw
2 months ago
5 months ago
Daikin Error Code 7H05
7 months ago
9 months ago
- 22 Forums
- 2,087 Topics
- 46 K Posts
- 16 Online
- 3,379 Members
And on the second day, we have a completed installation...
By Sheriff Fatman , 10 hours ago
Its the flow temperature for the heating circuit, it me...
By Gary , 10 hours ago
By JamesPa , 12 hours ago
When will heat pumps and install prices come down?
I am currently thinking about having a heat pump instal...
By EGP01 , 15 hours ago
By Old_Scientist , 16 hours ago
Adding battery storage to SolarEdge PV system
Hi, I think I've narrowed down my choice to a Sunsynk 5...
By nazuro1041 , 24 hours ago
Hi all - I'm diving into the world of ASHPs and I am tr...
By abam48 , 2 days ago
By abam48 , 3 days ago
By ASHP-BOBBA , 3 days ago
By benson , 4 days ago
By Mars , 5 days ago
By Bart , 6 days ago
