ASHP and Tado
Posted by: @gfletcher@morgan Brilliant - thanks, I'll look at the curve settings.
Hi Gavin,
Obviously you need to set the slope of the weather compensation to the requirements of your particular home. I would suggest that you start with the following settings and then fine tune as necessary.
Cold end: LWT of 50C at amb. of -5C.
Warm end: LWT of 25C at amb. of 20C.
The indoor temperature will probably change very slowly, so monitor your system for quite a number of hours and let it stabilise before making any adjustments.
I hope that this helps.
- 2,763 Topics
- 65 K Posts
- 2,228 Online
- 7,169 Members
RE: Vaillant Aurotherm - Heater Wire Position
Batpred I was trying to establish where the heater elle...
By trebor12345 , 28 minutes ago
Posted by: @jamespa At this point its probably worth...
By Rob of York , 47 minutes ago
@batpred thanks for getting a copy. Appreciate the supp...
By Mars , 10 hours ago
We have a 6.56kW solar PV system (16x 410W panels) inst...
By Rob of York , 15 hours ago
RE: Where heat loss surveys seem to go against practical reality
@cathoderay @jamespa I've managed to get some nice re...
By Rob of York , 2 days ago
RE: 7kW EV Charger Options Advice
Doh, not sure that I was thinking straight there, less ...
By Rusty , 2 days ago
I’m really liking reading through this thread and the r...
By Judith , 2 days ago
Thank you @trebor12345
By rgabor , 2 days ago
Panasonic Free Multi Z and Etherea Internal units.
My prospective installers have suggested the Panasonic ...
Great. You just need to find a way of cranking up your...
We had two heat pumps installed without Govt funding. H...
By Rob of York , 3 days ago
My Adapt is finally installed and running! Almost a yea...
By tomasmcguinness , 3 days ago
Thanks, @batpred. That integration is the one I have in...
