Anyone able to provide some feedback before I make my finale decision? Samsung vs Baxi vs Vaillant
@jamespa Thanks.
I did not instruct them not to insulate but I surmise they made the same decision as yours? There are lots of pipes there in a small space, so ventilation may be quite relevant, but I may ask them why they did not do it?
Right now I am questioning if I should ask them to come back to cut and fix the two slabs I asked them to leave so that it would make my life easier not to do this job on my own, but I am not sure if I have the right to ask for it (picture attached).
I am not so sure now if I should purchase Heavenwise, but as you said, it may offer benefits with some tariffs. I have signed up for Octopus cosy, while I am waiting for them to let me know if I could use intelligent flux (which combines the perk of having batteries).
They said that service will cost £150 which felt a little bit pricey when compared with the £80 I was used to paying for boiler service.
Posted by: @eliuccioI did not instruct them not to insulate but I surmise they made the same decision as yours? There are lots of pipes there in a small space, so ventilation may be quite relevant, but I may ask them why they did not do it?
Strictly they should be insulated (building regs I believe) to stop them 'leaching' heat from the tank, unless of course you want the heat for something else!
Posted by: @eliuccioI am not so sure now if I should purchase Heavenwise, but as you said, it may offer benefits with some tariffs. I have signed up for Octopus cosy, while I am waiting for them to let me know if I could use intelligent flux (which combines the perk of having batteries).
I think if I were on a relatively complex tarrif like Cosy I would probably opt for Havenwise, but I haven't got batteries which I gather you have. The Vaillant controls are extremely flexible and, unlike many of Vaillant's competitors, setting a time pattern changes the flow temperature rather than just switching it on and off. They are therefore undoubtedly capable of doing what is necessary to optimise for a complex tariff of this nature, but my brain isn't capable of working out what settings I would need to put in!
Posted by: @eliuccioThey said that service will cost £150 which felt a little bit pricey when compared with the £80 I was used to paying for boiler service
There was a whole thread about service costs and yes they appear to be high. If it includes the UVC service/inspection then perhaps a bit less so, worth asking.
Posted by: @eliuccioRight now I am questioning if I should ask them to come back to cut and fix the two slabs I asked them to leave so that it would make my life easier not to do this job on my own, but I am not sure if I have the right to ask for it (picture attached).
Personally i would say this is reinstatement which they should have done, but there is room for argument depending on the precise words of the contract. You need an angle grinder to cut the slabs, if they have one and you don't I would try to persuade them to do it!
Thanks @Jamespa!
Posted by: @jamespaStrictly they should be insulated (building regs I believe) to stop them 'leaching' heat from the tank, unless of course you want the heat for something else!
I will ask them why they are not and will also try to persuade them
Posted by: @jamespaI think if I were on a relatively complex tarrif like Cosy I would probably opt for Havenwise, but I haven't got batteries which I gather you have. The Vaillant controls are extremely flexible and, unlike many of Vaillant's competitors, setting a time pattern changes the flow temperature rather than just switching it on and off. They are therefore undoubtedly capable of doing what is necessary to optimise for a complex tariff of this nature, but my brain isn't capable of working out what settings I would need to put in!
Right now, Octopus offered these options:
- Switch to Intelligent Octopus Flux (Import and Export): This would mean changing your current Cosy Octopus import tariff and your existing export tariff (if you have one) to Intelligent Octopus Flux. This option is ideal for maximising your solar and battery usage with dynamic import and export prices.
- Keep Cosy Octopus (Import) and Pair with Outgoing Octopus (Export): You could stick with Cosy Octopus for your import (which is great for heat pumps) and then pair it with our Outgoing Octopus tariff for your export. Outgoing Octopus offers a competitive flat rate for the energy you send back to the grid.
So, I will have to work out what is best.
Posted by: @jamespaThere was a whole thread about service costs and yes they appear to be high. If it includes the UVC service/inspection then perhaps a bit less so, worth asking.
I will certainly ask!
Cheers!
E
Posted by: @eliuccioSo, I will have to work out what is best.
Indeed.
With a battery its presumably the battery controller that does all the heavy lifting with load optimisation, so I'm not sure Havenwise helps much, but that depends on size of battery and controller capabilities. You may need a years worth of data to work it all out for certain. I have been collecting data since I had my heat pump fitted so I have got some basis to work out a strategy as tarrifs shift.
- 2,122 Topics
- 46.6 K Posts
- 77 Online
- 4,529 Members
By Judith , 38 minutes ago
By JulianC , 9 hours ago
You may well be right, @jamespa.
By Majordennisbloodnok , 13 hours ago
By Judith , 14 hours ago
By JamesPa , 17 hours ago
By Grantmethestrength , 18 hours ago
By TRBob , 2 days ago
By normpang , 4 days ago
By ASHP-BOBBA , 5 days ago
